by Eck » Wed Nov 08, 2017 1:19 pm
As Kirk sad-- any 351W will bolt on to the Bronco regardless of year. The 94 and up are more desirable because they are roller blocks so the cam and lifters are hydraulic rollers instead of the flat tappet. You get a little bit more power out of those.
You should be able to take the EFI stuff off but you will have to get a 351W intake. The 351 is a little wider so the 302 intake will not work. Everything else should bolt back on. There are 2 front dress 351 mounting brackets that you will need (
https://www.tomsbroncoparts.com/product ... ering-pump) to attach power steering pump and alternator. I think I have them you can have. If you don't have power steering, you only need 1.
Pretty much the only plug and play is to get a 289 or 302 that was carburated. If you find a 302 that is EFI, you can just use all of the stuff on your current motor. If you step up to 351W you will need a new intake and those brackets to make the front dress work.
