Register •
FAQ
• Login
It is currently Thu Apr 25, 2024 5:10 am
[ 7 posts ] |
ScottBarnes
Joined: Fri Nov 25, 2011 7:34 am Posts: 415 Location: Breckenridge and Franktown, CO
WH Clydesdale Steering
Looks like I might have a slightly bent Tie Rod (guess it's officially called a drag link), so looking at options. I like keeping it stock, and definitely don't want to do anything with heims, but was looking at the Wild Horses Clydesdale setup as a potential. Sort of pricey, but looks like it could handle my style of off roading way better. Any experience here with this setup?
_________________ Go Hard or Go Home
Sat Nov 18, 2017 3:41 pm |
B.O.B.
Re: WH Clydesdale Steering
I have a new drag link if you need it. $75
Sat Nov 18, 2017 6:52 pm |
Those are so beefy you could probably race Baja with them.
Most of us are running GE one ton components from ruff stuff
Sat Nov 18, 2017 6:56 pm |
ScottBarnes
Sun Nov 19, 2017 7:25 am |
If you don't want to get into the reaming and other mods (track bar riser) to go with a tie rod over setup just stick with the adjustable linkage. If you decide to do a tie rod over, you can do it a lot cheaper with Ruffstuff 1 ton parts.
Sun Nov 19, 2017 10:00 am |
ScottBarnes
Sun Nov 19, 2017 1:45 pm |
I have a reamer floating around the club somewhere. Think Justin still has it.
Sun Nov 19, 2017 2:47 pm |
[ 7 posts ] |
