Fuel filler hose 2 x 1.75"??
Postby Jesus_man » Tue Dec 26, 2017 4:14 pm
Anyone know a good way to adapt a 2" tank connection to a 1.75" bronco connection?? I tried to force the 1.75 over the 2" and it wasn't working. Perhaps I need to disconnect the electrical connections and drop the tank to get this done?
Re: Fuel filler hose 2 x 1.75"??
Postby Kinder » Tue Dec 26, 2017 8:16 pm
Quick and cheap would be a exhaust pipe adapter, there is usually a good selection at Autozone if you have one by you.
Postby Jesus_man » Tue Dec 26, 2017 8:18 pm
Those are aluminized? Does that hold up ok to fuel? I have an O-Reileys and Carquest
Postby Kinder » Tue Dec 26, 2017 8:34 pm
Not sure if they are aluminized, I believe they are just mild steel and are weldable, likely the same material fuel tanks are made of.
Postby Jesus_man » Wed Dec 27, 2017 7:45 am
Good point. I'll see what I can find!
Postby BroncoCrawler » Sun Dec 31, 2017 9:52 am
Exhaust adapters work fine for fuel fillers. I have also used irrigation pipe adapters before. Murdoch's has some of those on hand
Sent from my XT1254 using Tapatalk
BroncoCrawler
Postby Jesus_man » Sun Dec 31, 2017 2:46 pm
I did end up with an exhaust adapter. Worked pretty good aside from really having to force the 1.75" side on. I even put the hose in hot water to soften it. But it's all back in. Now I am anxious to fill it up enough to see if the factory gauge still works.
