Register •
FAQ
• Login
It is currently Fri Apr 19, 2024 11:49 am
[ 7 posts ] |
Fuel filler hose 2 x 1.75"??
Anyone know a good way to adapt a 2" tank connection to a 1.75" bronco connection?? I tried to force the 1.75 over the 2" and it wasn't working. Perhaps I need to disconnect the electrical connections and drop the tank to get this done?
Tue Dec 26, 2017 5:14 pm |
Re: Fuel filler hose 2 x 1.75"??
Quick and cheap would be a exhaust pipe adapter, there is usually a good selection at Autozone if you have one by you.
Tue Dec 26, 2017 9:16 pm |
Those are aluminized? Does that hold up ok to fuel? I have an O-Reileys and Carquest
Tue Dec 26, 2017 9:18 pm |
Not sure if they are aluminized, I believe they are just mild steel and are weldable, likely the same material fuel tanks are made of.
Tue Dec 26, 2017 9:34 pm |
Good point. I'll see what I can find!
Wed Dec 27, 2017 8:45 am |
BroncoCrawler
Exhaust adapters work fine for fuel fillers. I have also used irrigation pipe adapters before. Murdoch's has some of those on hand
Sent from my XT1254 using Tapatalk
Sun Dec 31, 2017 10:52 am |
I did end up with an exhaust adapter. Worked pretty good aside from really having to force the 1.75" side on. I even put the hose in hot water to soften it. But it's all back in. Now I am anxious to fill it up enough to see if the factory gauge still works.
Sun Dec 31, 2017 3:46 pm |
[ 7 posts ] |
