Ax15
Ax15
Postby Mr. Lav » Mon Mar 19, 2018 5:42 pm
Question for you all. Has any body put an ax15 behind a six cylinder? Looking for thoughts on this thinking of a daily driver. I know need to finish the daughters 74 first. Found a 66 half cab like I said just thinking
Mr. Lav
Re: Ax15
Postby Kinder » Tue Mar 20, 2018 8:04 am
I don’t think I’ve seen that done, as long as there is a bell housing to get from the small 6 (144-200) to the AX15 you can make it happen.
I bet it’s been a discussion item on fordsix.com
Ax15
Postby Kinder » Tue Mar 20, 2018 8:32 am
A little research and a few missing links.
Novak makes an adapter to get from the Ford “butterfly” bell housing to the AX15. And the factory small 6 bell housing is a butterfly housing.
https://www.novak-adapt.com/catalog/ada ... it-fmax15/
Of course then you have to get to the D20.
http://www.advanceadapters.com/products ... o-dana-20/
It’s only money.
Re: Ax15
Postby Mr. Lav » Tue Mar 20, 2018 4:25 pm
I 've seen the kits from wild horses just wanting to make sure the bell housing on the six will work. What is the difference between the 6 and 8 trans? A buddy of mine just rolled his 97 wrangler and is giving me the trans.
And what is money haven't seen that stuff in a while .
Mr. Lav
Re: Ax15
Postby Viperwolf1 » Tue Mar 20, 2018 8:14 pm
It looks to me like Novak describes the butterfly pattern as the standard small block pattern. In which case a falcon six will not work unless it was 1980s vintage. The 250 and 240/300 used the small block pattern.
Re: Ax15
Postby Mr. Lav » Tue Mar 20, 2018 8:39 pm
Thanks talked to Matt at wild horses need to find a 11 inch fly wheel and bell housing. So maybe an 80's truck bell housing will work?
Mr. Lav
