1967 Bronco Auto Trans
Postby daveott3@aol.com » Wed Mar 28, 2018 1:55 pm
I have a customer that is a member of this forum that has a really nice 67 Bronco, V8, Automatic, lift kit, mostly restored. Unfortunately the 3 speed automatic transmission has a bunch of clutch debris in the pan. We are looking to install a later model 4 speed OD transmission in the vehicle. What do I need to know to do the exchange? Obviously, the transfer case, etc., but what else needs to be obtained or modified for the swap? Thanks!
daveott3@aol.com
Re: 1967 Bronco Auto Trans
Postby ZOSO » Wed Mar 28, 2018 2:02 pm
Is this bronco EFI'd or still carb'd?
All depends on what trans you want to run. You can get an AOD out of a mustang and change the tailhousing and output shaft with an adaptor to the d20. But a far superior transmission to use is a 4r70w out of a 96-01 ford explorer. It has better gearing and a much stronger build. They will bolt up directly to the 302 and with a bolt on adaptor it will mate to the d20. The 4r70w will require modifications to the trans cross member and driveshafts. It is also all electronically controlled. So either an aftermarket controller or can be controlled off the factory explorer efi system if so equipped.
Our local trans guru is Viperwolf1. He can hook you up with a bulletproof c4 if needed.
Postby Eck » Wed Mar 28, 2018 2:02 pm
daveott3@aol.com wrote:I have a customer that is a member of this forum that has a really nice 67 Bronco, V8, Automatic, lift kit, mostly restored. Unfortunately the 3 speed automatic transmission has a bunch of clutch debris in the pan. We are looking to install a later model 4 speed OD transmission in the vehicle. What do I need to know to do the exchange? Obviously, the transfer case, etc., but what else needs to be obtained or modified for the swap? Thanks!
Which transmission would help.
Postby daveott3@aol.com » Wed Apr 04, 2018 7:27 pm
It has a Holley 4bbl. Sorry. I didn't have my notifications enabled. I will respond promptly now that I figured it out!
daveott3@aol.com
