D44 Warn locking hubs
Postby mustangjonny84 » Mon Aug 06, 2018 5:07 pm
Last winter, I had some issues with my current hubs. I know a lot of you guys know my truck better than I do so I'm looking here for help. Pictured below is what I've got now. My front axle is a "79' Bronco dana44 highpinion with 76' f250 knuckle out". I'd like to get Warn Premium locking hubs. Being Frankenstein's monster, I'm just not sure which one to go with.
Some sites say the Warn 9072...
Some sites say the Warn 20990...
From what I've read so far, the difference has to do with the outer diameter of the axle shaft. Any ideas so that I can make the purchase before taring into my axle??
Last edited by mustangjonny84 on Thu Aug 09, 2018 11:07 am, edited 1 time in total.
1975 Bronco- 302 w/ EFI,NP435,twin stick D20, D44, D60, 4.5" WH lift, 1" body lift, 35" Nitto Trail Grapplers
2012 Flex Ecoboost - VTA mod
2003 Mustang Mach 1- K&N,SSS catback
1992 GMC Bread Van - wife's food truck...The G-Spot
2003 Suzuki SV1000- GSXR fork,Danmoto cans,carbon fiber fender, lots of stuff painted black
1980 CB750 cafe- GSXR fork,K&N,CBR coil packs,Chappell customs seat,MAC 4/1 exhaust
mustangjonny84
Re: D44 Warn locking hubs
Postby Jesus_man » Tue Aug 07, 2018 7:39 am
Before you replace, you should pull them apart and have a look-see. Perhaps it's an easy fix? Sometimes even too much grease creates more vacuum then the spring can overcome (especially in the cold) and all that is needed is a good cleaning and a light coating of lithium grease.
But based on internet pics, those look like stock F-250 hubs.
Postby RJLougee » Wed Aug 08, 2018 8:19 pm
They both fit the 19 spline axles, so it's not an axle shaft size issue.
The #20990 is designed for the standard internal locking hubs like we have on the EB.
The #9072 is designed for the external locking hubs commonly found on the 3/4 ton trucks (not the 1 ton, D60 setup).
I cannot tell which you have looking at the pic. Maybe a shot from the side without a wheel on?
HTH, Joe
RJLougee
Postby mustangjonny84 » Thu Aug 09, 2018 10:48 am
Here's a side view of my current hub...
mustangjonny84
Postby sykanr0ng » Thu Aug 09, 2018 2:08 pm
That sure looks like a heavy duty Spicer hub that was used on the highboy F250
sykanr0ng
Postby RJLougee » Tue Aug 14, 2018 6:59 pm
That still looks like an external assy. However, I'm only 85% sure, not 100%.
Can we get a pic without a wheel on there?
Joe
RJLougee
Postby mustangjonny84 » Wed Aug 22, 2018 7:21 pm
Jesus_man wrote:Before you replace, you should pull them apart and have a look-see. Perhaps it's an easy fix? Sometimes even too much grease creates more vacuum then the spring can overcome (especially in the cold) and all that is needed is a good cleaning and a light coating of lithium grease.
Yeah, there was some gunk. I'm going to clean them up and see if I can get better operation out of them. There did not appear to be any breakage/defects inside.
RJLougee wrote:That still looks like an external assy. However, I'm only 85% sure, not 100%.
Joe
Joe,
Methinks you were 100% right. After a few more lessons from the interwebs, I decided to go with my (our) gut and get the 9072. No road test yet. But the movement is MUCH smoother and they look pretty sharp too!
mustangjonny84
