www.ColoradoClassicBroncos.com - View topic - Steering column options
It is currently Sun Jun 16, 2024 8:26 pm
Reply to topic  [ 7 posts ]
Post Steering column options
So my rig still has the old style solid steering shaft and I would prefer not to become shish kabob in an accident. While the engine is out, I thought about pulling the shaft, cutting it down and milling flats for a double-D steering joint, then adding a collapsible steering shaft.
For the guys with earlier EBs, what have you done to upgrade the steering shaft?
Build Thread:
Fri Feb 22, 2019 9:17 am
Post Re: Steering column options
Another option would be to find a short upper shaft that is already splined on the lower end. Those were found on '73-'77 power steer columns. This just means you'll use a different upper u-joint though. You do want a collapsible lower shaft.
Fri Feb 22, 2019 10:04 am
I'm running a column out of a 2wd '71 F150. It's a hair shorter than the original, but works fine and got me the splined shaft I needed.
Sat Feb 23, 2019 12:26 am
I just gave measurements and details to a bronco vendor and had them make me one. It's been great for several years now. But something tells me, you are not quite happy with just ordering something...
Mon Feb 25, 2019 8:15 am
Build Thread:
Mon Feb 25, 2019 4:16 pm
XJs have a nice factory collapsible lower steering shaft. I've integrated several of them into projects over the years.
Many ways to do it, cut/weld onto a stock shaft; add a splined joint at one or each end; cut/weld a double 'D' u-joint; etc... I'm actually running a Scout PS gearbox on mine, so it has the same 3/4" splined joint at the bottom for me, vs. the 13/16" EB box.
HTH, Joe
Sat Mar 16, 2019 3:51 pm
Build Thread:
Sat Mar 16, 2019 9:18 pm
30,561,729 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
