landshark wrote:Great time today - and its not often that the truck runs better going home from a trail run then it does going to the trail...
BTW the front drive shaft wasn't the culprit making the vibration. I pulled the York off the bracket and the vibration stopped... so some crazy frequencies coming through that bracket!
Jesus_man wrote:You've copied the wrong text from photobucket... Copy the one next to "Image Code"
Jesus_man wrote:post a link to your entire album (assuming you've uploaded them all)
Thanks for sharing. You got some great shots! We should have gotten a picture of that broken axle shaft.
ZOSO wrote:Hey greg, the jeep was brian not bill. And its kirk not curt...
Booger wrote:landshark wrote:Great time today - and its not often that the truck runs better going home from a trail run then it does going to the trail...
That's pretty wild. Well at least you isolated it. So is the York or clutch the issue?
Booger wrote:I forgot to give JD congrats on MOTM. Congrats JD.
