by Entourage » Thu May 31, 2012 9:32 am
The June 2012 Breakfast will be held in Denver on Father's Day Weekend.
The Top Series of NASCAR is the Sprint Cup Series. 42 Racing teams are headquartered in North Carolina. Only One Sprint Cup team is located outside North Carolina and Denver is lucky to be home to the #78 Furniture Row Racing Team. Even better, Mike Root, a CCB Member, is their painter and getting CCB unparalleled behind-the-scenes access to the 35,000 sq.ft. world class Race Shop, right here in Denver.
Driver of the #78, Regan Smith had an amazing 2011 Season, winning at Darlington Southern 500, and finishing in the top 10 five times — 7th at Daytona 500 (The NASCAR Super Bowl), 8th at Coca-Cola 600 in Charlotte, and 3rd at Brickyard 400 in Indianapolis, the NASCAR equivalent to the Indy 500. The 2012 Season is just as exciting.
Join us for Santiago’s Breakfast Burritos, tour of this world-class racing shop, paint booth, simulator, dyno, etc. followed by a group photo with the #78 Car. A big thanks to Mike for putting this amazing event together. Even if you are not a NASCAR Fan, this is a chance to see one of the nicest race shops anywhere in the world with a top team with behind the scenes access.
This is sure to be the fastest Breakfast With Broncos yet - Hope to See You There!
When:
Saturday, June 16th, 2012
Time:
8:00 AM
Where:
4000 Forest Street
Denver, CO 80216
303.322.2008
(Stapleton Area - Colorado Blvd. and 42nd)
Cost:
$2.00 Per Burrito
*Please RSVP below so we have enough Burritos by 6/15/2012*
Specs on the #78 Furniture Row NASCAR Sprint Cup Car:
• ENGINE: GM V8
• HORSEPOWER: 850 @ 8800 RPM
• COMPRESSION RATIO: 12.5:1
• TORQUE: 540 ft/lb @ 7500 RPM
• MAXIMUM DISPLACEMENT: 358 cu. inches
• INDUCTION: Fuel Injected
• FRONT SUSPENSION: Independent coil springs, twin control arms
• REAR SUSPENSION: Trailing arms, coil springs, pan hard bar
• WHEEL BASE: 110 Inches
• WHEELS: Steel 15 x 9.5 inches
• TIRES: Goodyear Racing Eagle
• TREAD WIDTH: 60.5 inches
• TOP SPEED: 200+ MPH
• IGNITION SYSTEM: MSD
• TRANSMISSION: Manual 4 speed
• FUEL: Sunoco 260 GTX Unleaded
• FUEL CAPACITY: 18 Gallons
• BODY LENGTH: 200 inches
• BODY WIDTH: 74 inches
• HEIGHT: 51 inches
• WEIGHT: 3,400 lbs. plus driver
• FRONT AIR DAM: 4.0 inches from the ground
• GEAR RATIO: 2.90 – 6.33:1
