30 years of collecting eb parts dont need em anymore
4 driveshafts 2frt, 2rear - these are extra heavy duty,stock are 1/8 wall these are 1/4 wall, they would be to long but can be cut down ( my eb has extended whl base) 25$
d44 is missing axles and brakes,{i have stock brake parts| 3.54 gear, has drag link and tie rod 15$
d30 has axles and warn hubs, brakes and lines 3.50 gear 20$
1 t shift t case - 2 adapters 20$
2 j shift t cases, box of t case parts 20$
5 flywheels 10$
4 assorted bell housees all for 302 10$
1 frt disc and hub {new} 10$
box of frt hub parts
2 outer stub axles(probally moser) 15$
5 assorted pitman arms 15$
2 crossmembers 5$
6 brake drums and back plates 10$
5 15x 8 steel spoke wheels 10$
box of ford frt hub parts 10$
1 set of stock rear leaf springs 10$
box of good usable u-joints (driveshaft and 44 frts.) 10$
4 tie rod drag link assemblies 10$
1 sets of mustang heads (prety darn cleand up, you could just bolt em on) 20$
1 set of cast exhaust man. has o2 sensors 10$
call or text 720 934 0806------- since I am device challenged its best to call 303-794-6001 len
