Removed this yesterday from TFB, it includes everything needed to swap a pan fill C4 into a 3 spd or 4 spd manual truck. Transmission was rebuilt by Viper w/ a mild shift kit about 7-8 yrs ago, it has approximately 30-40k miles on it. It was never mistreated and never leaked or ran low on fluid. Included are hard factory cooler lines and external cooler or if you’d rather have a radiator with built in cooler I’ll include that, vacuum line and column shift rod, cross member w/ good bushings, and It has an EFI down shift cable setup on it. I have an auto column from a ‘78/79 F-150 if you need a column.
The ONLY reason I pulled this out was to replace it with a manual for the boy! I know he’ll regret it in traffic, but talking sense into a 23yo is a foolish act.
Price is $750 w/out column, $900 with column. If you need it installed or would like to have me perform the swap on your bronco we can talk about labor costs. I’ll clean the case up a bit to get the grime off of it. I’m not interested in selling any parts separately at the moment.
