www.ColoradoClassicBroncos.com - View topic - Transmissions and T-Cases.
It is currently Mon May 13, 2024 12:46 pm
Reply to topic  [ 2 posts ]
Post Transmissions and T-Cases.
I need to clean out the shop and here are some transmissions I have for sale:
1. I have two 4WD E4OD trans from 95 and 96 Broncos with the 5.8. Both trucks were running when parted out, but the trans have been sitting. $200/each.
2. I have a C-4 that used to be in the buggy, was rebuilt a couple years ago and has a Broader Performance full manual/reverse valve body, deep pan and Lokar locking trans fill tube. $1000.
3. I have a SBF C-6 trans, probably need a rebuild, but has the correct tailhousing/adapter to put a D20 transfer case on the back of it. $500.
4. I have a built AOD, SBF regular 4WD tailhousing. Pulled from my Bronco this month, going back to a ZF. Wide ratio gear set, set up for 1, 2, 3/4 shift pattern. $750.
5. I have a BBF 4WD ZF available. $500.
6. I also have a couple BW1356 transfer cases, one good manual shift/spedo hole/long output yoke: $250. One the same needs rebuild $100 and one from a 95 Bronco, electric shift, flange output $350.
If you don't like my prices, make me an offer. Posting here for now, on to Craigslist after the weekend.
Joe
Wed May 19, 2021 11:59 am
Post Re: Transmissions and T-Cases.
Please call me @ 719 738 1229
Thu Jun 10, 2021 10:03 am
28,879,262 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
