Register •
FAQ
• Login
It is currently Mon May 13, 2024 1:36 pm
[ 5 posts ] |
B.O.B.
ARB Air Locker - RD117
I have an air locker for a 44 . Pt# RD117. Designed for 3.73 and down gears. May be able to use for higher ratio with the right gear set. Comes with a seal housing. Will need bearings. $600 obo.
Thu Feb 22, 2024 12:46 pm |
TOOLMAN
Re: ARB Air Locker - RD117
By 3.73 and higher do you mean like a 3.50? If it works for 4.11 I would be interested.
Fri Feb 23, 2024 2:39 pm |
phyler
Probably needs the "thick" gears to work with 4.xx gears. If I didn't already own the gears and carrier, I'd be all over this.
Sent from my Pixel 8 Pro using Tapatalk
Fri Feb 23, 2024 5:06 pm |
B.O.B.
That is correct. 3.73 , 3.50, etc. if you can find the thicker gear set then you would be in business. I have the rd116 which is for 3.92 and up, but that’s for mine.
Fri Feb 23, 2024 6:08 pm |
TOOLMAN
Thu Feb 29, 2024 9:00 am |
[ 5 posts ] |
