www.ColoradoClassicBroncos.com - View topic - Sort of Bronco related, 4BT
It is currently Mon Sep 23, 2024 11:14 pm
Reply to topic  [ 2 posts ]
Post Sort of Bronco related, 4BT
Not mine, but for you ambicious guys:
https://cosprings.craigslist.org/pts/4899078902.html
Thu Feb 19, 2015 6:06 pm
Post Re: Sort of Bronco related, 4BT
I can't see the pump 2 confirm it, but looks like a rotary pump motor. Has a vacuum pump on it & a rear mounted turbo that seems to have the Ford tilt to it, so likely a re power in a Ford chassis.
It's been rebuilt at some point, sticker on the 1st valve cover. Make sure you pull the SN or CPL to confirm its history.
Thu Feb 19, 2015 6:14 pm
32,327,199 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
