Register •
FAQ
• Login
It is currently Sun Sep 22, 2024 11:28 pm
[ 1 post ] |
rooster
Joined: Thu Feb 12, 2015 8:29 pm Posts: 176 Images: 0 Location: Platteville
5.0l and EFI parts sale!
Hey all , have a bunch of leftover EFI stuff I don't have any use for, thought Mabey someone could get some use out of em! - 90 mustang 5.0 serpentine belt front dress. It includes the crank pulley, water pump pulley, alternator(130 amp motorcraft) with bracket and tensioner , aswell as powersteering pump and bracket. $125 - 5.0 pilot bearing brand new $5 - explorer 5.0 headers and 90 degree elbow. $30 - EFI fuel lines with flexible stainless line and spring lock connectors $10 - explorer 5.0 powersteering resivor $10 - intake cover "5.0l v8". $15 -washer fluid tank ( came out of 2000 f-150 ) but should fit into a bronco fairly easily, includes pump. $10 - upper/lower 5.0 intake , fuel rail, and injectors. $60 - tore down 5.0 , motor should probably be rebuilt as some fuel was seeping into the oil, probably caused by my poor wiring injectors at the time... It has e6 heads I believe, if you do some research the e6 heads are accually better for building a torquey motor than e7s . It has 50 oz imbalance balancer and flexplate $75 pM me for more pics or info, thanks!
Sat Feb 28, 2015 2:44 pm |
[ 1 post ] |
Users browsing this forum: Google [Bot] and 3 guests |
