It is currently Fri Mar 29, 2024 7:39 am
[ 9 posts ] |
D44 Housing/4.56 gears/D20 - SOLD
pgilbeau
Need to keep clearing out the garage so listing a couple more things. Everything came off of my Bronco and was functional when pulled.
Early Bronco D44 low pinion housing, believe its a '72, SOLD 4.56 ring and pinion from low pinion D44, SOLD D20 with older Duffy shifter, SOLD
Sat Feb 25, 2017 4:09 pm |
pgilbeau
Re: D44 Housing/4.56 gears/D20
Added better pics of the gears for those that asked.
Sun Feb 26, 2017 2:53 pm |
pgilbeau
Sale pending on housing and gears- SOLD
Sun Feb 26, 2017 3:22 pm |
Thank god. I was sitting over here wondering what the hell I'd do with three housings.
Sun Feb 26, 2017 11:46 pm |
Mon Feb 27, 2017 9:08 am |
Nah. Once I get the Baja moving under its own power I'm going to purge, save enough for one more Bronco.
Mon Feb 27, 2017 9:23 am |
Mon Feb 27, 2017 10:21 am |
pgilbeau
Mon Feb 27, 2017 8:52 pm |
Which is why I plan to keep enough parts for one more Bronco. ;)
Mon Feb 27, 2017 9:59 pm |
[ 9 posts ] |
