www.ColoradoClassicBroncos.com - View topic - 75 Bronco Parts Purge
It is currently Tue May 14, 2024 12:40 pm
Reply to topic  [ 17 posts ]
Post 75 Bronco Parts Purge
I'm at the point on my build where I will no longer be needing the parts listed below all parts are off a 1975 Bronco 302 with 137K.
Parts are located for local pick up in Frederick CO. Will post pictures during the day.
Thanks
Steve
Rear Leaf Spring 20.00
302 Air Filter 20.00
302 Exhaust heat shield 10.00
(SOLD to kbank6) Passenger side inner wheel well 20.00
(SOLD to kbanks6) Driver side inner wheel well 20.00
(SOLD to FRIDAY)Transfer case skid plate 10.00
(SOLD to FRIDAY) Radius arm set 40.00
Front bumper minus the license bracket 30.00
Front license bracket 20.00
Rear bumper w/Ford stamped hitch 30.00
(SOLD to LA HI)302 radiator 20.00 (need flushed/cleaned no leaks)
(SOLD TO LA HI)302 radiator shroud 20.00
(SOLD)fuel tank transfer switch 20.00
(SOLD)front fuel tank tube 10.00
(SOLD)rear fuel tanks tube 10.00
Front springs 10.00
302 heads 20.00
exhaust manifolds 20.00
Power steering pump 20.00
302 intake manifold 20.00
electronic distributor 20.00
2-barrel carb 20.00 ( needs rebuilt)
(SOLD TO LA HI) 6-blade radiator fan blade 20.00
OEM jack and lug wrench 20.00
Steering wheel 20.00
Thu Aug 02, 2018 9:20 am
Post Re: 75 Bronco Parts Purge
Parts pictures
Thu Aug 02, 2018 9:24 am
More Pics
Thu Aug 02, 2018 9:27 am
more
Thu Aug 02, 2018 9:30 am
more
Thu Aug 02, 2018 9:37 am
more
Thu Aug 02, 2018 9:38 am
last ones
Sorry no pic of the jack parts today
Thu Aug 02, 2018 9:40 am
Don’t know if you care but that license plate mount for the front bumper is worth $40 or so. They are slightly rare.
Thu Aug 02, 2018 9:45 am
Thu Aug 02, 2018 10:01 am
I'll take the radius arms and the transfer case skid plate if still available.
Thu Aug 02, 2018 10:07 am
Profile WWW
Thu Aug 02, 2018 10:10 am
I’ll take both wheel wells if available.
Sat Aug 04, 2018 5:19 pm
Hey kbank6
The wheel wheels are still available. Pm sent
Sat Aug 04, 2018 7:01 pm
any parts still available, interested in the radiator and jack specifically
Sun Mar 24, 2019 5:03 pm
Hey reallytallman,
The radiator is sold, but I'm sure I have the jack somewhere in the garage lol. I'll check when I get home
Mon Mar 25, 2019 9:51 am
Is the power steering pump still good? Is it the same as a ‘73? Mine’s leaking pretty bad
Sat Mar 30, 2019 9:30 am
Hey EBsaver,
sorry for the delay reply I was in AZ for a week and out of the loop. I'm pretty sure its good but not sure if 73 -75 are the same ?
I'll sent you a PM
Wed Apr 03, 2019 1:20 pm
28,936,127 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
