It is currently Wed Oct 02, 2024 2:20 am
[ 10 posts ] |
Mildly built 351W, F4TE Roller Block
I'm putting a feeler out there, judging interest in this engine. - 1994 T4FE 351W roller block bored .030 over - Original crate engine built by Detroit Competition Engineering in late 2009, ~25k-30k miles - 9:1 compression - 4340 I-beam rods and forged pistons, ARP hardware - SFI 28oz flywheel and balancer - ProComp SBF 210 aluminum heads - CompCams 35-329-8 roller cam. (est 350HP @ 5000 rpm / 425 lbft @ 3500 rpm) [I also have the higher HP/higher RPM TrickFlow cam available as well] installed recently - CompCams timing chain (installed recently) - 1.6:1 CompCams roller rockers, ARP studs and guide plates - MSD distributor and wiring - Aluminum tall valve covers - High flow water pump - Miloden 7qt oil pan - Choice of Weiand Stealth or Edelbrock Torker II (new) intake. (Intake currently removed) - V-belt front dress with 130 amp 3G alternator and Saginaw P-pump Other stuff that can be included: - 36-1 crank wheel and 3.0l VR sensor with custom brackets - 1000 CFM FAST 4150 EFI throttle body - pre-wired Megasquirt EFI I have $7100 in receipts. Asking $3000, but I'm not sure what the going rate is for a used crate engine, so I'm open to offers.
Mon Dec 03, 2018 11:31 pm |
Re: Mildly built 351W, F4TE Roller Block
That’s a great deal! If I have already built one. I would be all over it
Tue Dec 04, 2018 9:04 am |
TOOLMAN
What direction are you going now (re: why are you getting rid of this one)?
Tue Dec 04, 2018 10:11 am |
phyler
Tue Dec 04, 2018 10:44 am |
Tue Dec 04, 2018 12:35 pm |
I don't want to derail your FOR SALE thread here, but I am certainly intrigued in what you have in mind for the diesel conversion. 2.8 Cummins?
Tue Dec 04, 2018 4:11 pm |
Tue Dec 04, 2018 4:35 pm |
I'm sorry. Didn't mean to let you cat out of his bag... But I am so excited to a) have another diesel conversion to over, and b) a R2.8 in an EB!!!!!!! Adapter? pfffttt a walk in the park for a fella like yourself!
Tue Dec 04, 2018 6:09 pm |
Damn that is very tempting to pick this up from ya if I had the funds. Im low key looking for a roller block to start a new build for the 3rd time.
Tue Dec 04, 2018 9:32 pm |
Pepe
I’m interested give me a call 970-904-0955
Mon Dec 17, 2018 10:01 pm |
[ 10 posts ] |
