Digger wrote:Yes, the ZF5 does bolt straight to the Atlas. It does require a spacer, but I went the simple route and shortened the output shaft by 1/2".
I don’t think any small block zf’s were anything other than s5-42’s were there? I think the 47’s were behind diesels for the most part but maybe I am mistaken.Digger wrote:Just look at the tag on the driver's side of the transmission. It will have a ZF and Ford logo and right below that, a P/N. You want the S5-42 or S5-47
landshark wrote:[I don’t think any small block zf’s were anything other than s5-42’s were there? I think the 47’s were behind diesels for the most part but maybe I am mistaken.
Mine is from a 97 f-250. It's the 47.Kinder wrote:landshark wrote:[I don’t think any small block zf’s were anything other than s5-42’s were there? I think the 47’s were behind diesels for the most part but maybe I am mistaken.
The last two’ish years there were S5-47s behind Windsor small blocks, but only the larger 3/4 or 1 ton. Mine was pulled from a ‘97-98 F350 crew cab 4x4.
