Oring Seal Kit for ARB RD119 locker - Ford 9" 31 spline
Postby Rox Crusher » Sun Aug 30, 2020 7:36 am
Does anybody happen to have the replacement oring set for an ARB RD119 locker ?
Instruction Manual says they are part number 160235SP.
I can get the off ebay but not soon enough.
Re: Oring Seal Kit for ARB RD119 locker - Ford 9" 31 spline
Postby horseplay » Sun Aug 30, 2020 11:35 am
High country 4x4 should have them. I wish I was closer I keep them in stock as well. I bet 4wheel parts has them as well.
horseplay
Postby B.O.B. » Sun Aug 30, 2020 1:19 pm
I can check tomorrow when I get to work how fast I can grab one
B.O.B.
Postby Eck » Sun Aug 30, 2020 2:34 pm
https://www.northridge4x4.com/part/lock ... NEQAvD_BwE
Another option local.
Postby Rox Crusher » Sun Aug 30, 2020 2:45 pm
B.O.B. wrote:I can check tomorrow when I get to work how fast I can grab one
Thank you Bob that would be great
Postby Digger » Mon Aug 31, 2020 7:25 pm
I have 8 of those o-rings, you are welcome to have a few.
For reference, those o-rings are -133 size Viton. I bought McMaster P/N 120T792 to use as replacements. I think you can also use McMaster 6540K236, which is the X-profile, providing a better seal, but I have been running 100,000+ trouble free miles on convention round profile o-rings.
Postby Kinder » Wed Sep 02, 2020 7:20 am
If you are handing out spares I’d like to grab one for TFB, I think his is failing.
Postby Digger » Wed Sep 02, 2020 8:42 pm
sure, no problem
Postby Eck » Mon Sep 14, 2020 6:42 pm
Digger wrote:I have 8 of those o-rings, you are welcome to have a few.
Just ordered the X-profile rings you suggested. Ended up having a leak up in Buena Vista so need to open it up and figure it out. Any further recommendations on how to install this thing to best avoid the dreaded air leak and locker failure?
Return to Bronco Parts Wanted
