Removed
Removed
Postby airbur » Thu Aug 25, 2011 7:29 pm
Removed
airbur
Re: WTB: 1972+ Bronco C4 Tranny
Postby Rox Crusher » Thu Aug 25, 2011 7:34 pm
Have you called Viperwolf1 over at C4s-R-US ?
Postby airbur » Thu Aug 25, 2011 7:48 pm
Haha....he's who gave me the specs and parts needed:)
airbur
Postby Entourage » Thu Aug 25, 2011 8:53 pm
Postby Colorado75bronc » Fri Aug 26, 2011 5:21 pm
if you're building a 427 stroker, i would highly recommend going to a C6 instead of the C4, thats alot of torque to be putting through that little C4 in my opinion, and a C6 is bulletproof in comparison
Colorado75bronc
Postby airbur » Fri Aug 26, 2011 5:46 pm
Thanks man. I will either be doing the AODE or a Viper built c4 which can handle a 427:)
airbur
Postby ZOSO » Fri Aug 26, 2011 8:23 pm
Colorado75bronc wrote:if you're building a 427 stroker, i would highly recommend going to a C6 instead of the C4, thats alot of torque to be putting through that little C4 in my opinion, and a C6 is bulletproof in comparison
I have seen plenty of c4's take 800-900 wheel horsepower and torque easily.
Postby Colorado75bronc » Sat Aug 27, 2011 1:57 pm
in a racing scene ya, i just don't picture it being as reliable for a regularly driven truck not to mention a truck that weighs more and rides on much larger tires, i know you can build em' to be stout, but just to start a c-6 is far stronger and more reliable in stock form, for that much power i would want the best possible, im hard on my vehicles and need them to be able to take it, but im sure viper will hook ya up, like i said just my recommendation
Colorado75bronc
Postby airbur » Sat Aug 27, 2011 2:01 pm
Hows the install on the c6? Is it a bolt up? Any fab work necessary?
airbur
Postby Viperwolf1 » Sat Aug 27, 2011 3:39 pm
Colorado75bronc wrote:in a racing scene ya, i just don't picture it being as reliable for a regularly driven truck not to mention a truck that weighs more and rides on much larger tires, i know you can build em' to be stout, but just to start a c-6 is far stronger and more reliable in stock form, for that much power i would want the best possible, im hard on my vehicles and need them to be able to take it, but im sure viper will hook ya up, like i said just my recommendation
C4's were stock in 2wd trucks (including the F250) with engines up to the 351W from about '66 until the early '80's. Many early '70's big cars with the 351C had them. Some of the mid '70's cars with the 400 used them too. Don't let the small size fool you, they are tough if built right.
Postby ZOSO » Sat Aug 27, 2011 5:01 pm
Keep it cool and you wont have an issue. Heat is the number one killer for an auto tranny. My dads c4 has takin a beating and keeps workin. Pre-cooler its not uncommon for temps to get to 280*
I do know what your saying but I dont think he'll have an issue as long as he keeps it cool.
Re: Removed.
Postby airbur » Thu Sep 15, 2011 3:56 am
Found a cheap, rebuildable 4R70W. Thanks guys.
airbur
Return to Bronco Parts Wanted
