5.0 Explorer oil pan
Postby Rox Crusher » Sat Aug 27, 2011 9:15 am
Looking for an Explorer 5.0 oil pan
They came in steel and aluminum and I would like a steel one.
Anybody happen to have what I am looking for or know where I can get it ?
Re: 5.0 Explorer oil pan
Postby Moab Mike » Sat Aug 27, 2011 1:53 pm
Rox Crusher wrote:Looking for an Explorer 5.0 oil pan
I have an EB oil pan off of a 74'. It's yours for the asking.
Moab Mike
Postby Rox Crusher » Sat Aug 27, 2011 2:39 pm
I'm not sure that an early 302 pan will fit a 5.0 ?
Postby Moab Mike » Sat Aug 27, 2011 2:50 pm
Me either, I thought I'd keep the gray matter flowing with electrons.
Moab Mike
Postby Viperwolf1 » Sat Aug 27, 2011 3:42 pm
It can work. The difference is the newer block has hole in the pan rail for the new style dipstick and the EB pan is not clearanced for it. You could plug the hole in the block to make it work.
Postby Gunnibronco » Sat Aug 27, 2011 4:47 pm
Why do you want the steel Explorer pan instead of the aluminum? Just wondering because my Explorer motor has the aluminum pan.
Chad
Postby Rox Crusher » Sat Aug 27, 2011 5:38 pm
Gunnibronco wrote:Why do you want the steel Explorer pan instead of the aluminum? Just wondering because my Explorer motor has the aluminum pan.
Chad
Steel would be more forgiving if something were to hit it. It might bend rather than crack like the aluminum would.
My 5.0 has a steel pan but the PO beat it with a hammer to get it to fit into the Ranger he was installing it in.
Postby Gunnibronco » Sat Aug 27, 2011 6:47 pm
Right on, thought they might be different shape and have issues fitting or something.
Thanks
Chad
Postby akaFrankCastle » Wed Sep 14, 2011 8:44 pm
Couple of 5.0 Exploders at the U Pull here in town (all the top ends are gone. thanks scavengers).
Still need one I can pull one for you.
Return to Bronco Parts Wanted
