www.ColoradoClassicBroncos.com - View topic - Rear axle shaft
It is currently Fri Nov 01, 2024 12:34 pm
Reply to topic  [ 9 posts ]
 Rear axle shaft
Post Rear axle shaft
Need a stock rear axle shaft - 28 spline.
Anyone have one or two lying about they want to get rid of (hopefully cheap)?
Thanks
Fri Sep 21, 2012 9:39 am
Post Re: Rear axle shaft
Big bearing or small?
Fri Sep 21, 2012 2:27 pm
Should b sml, I'm your huckleberry, which side?
Fri Sep 21, 2012 2:30 pm
Not sure yet. I think small but will confirm when I get home tonight.
Have to replace the seal and possibly the bearing, I am thinking a bent shaft might have caused this.... and Drew's "clunk"
Fri Sep 21, 2012 2:33 pm
photo was taken this am after Drew drove to school. No leak (from the rear axle in the street)
Fri Sep 21, 2012 2:39 pm
My buddy might still have my old small bearing axles, and I think the left rear was good
Fri Sep 21, 2012 7:16 pm
And I thought I was leaving puddles behind in my Bronco.
Fri Sep 21, 2012 7:18 pm
Let me check I believe I have a set
Fri Oct 05, 2012 7:04 am
That would be awesome. We need the big bearing, 11" drum, 28 spline shafts. But not from 76-77, those are about 3/8" longer and would require changing out backing plates and all the brake parts.
If you have them that would be great!
Thanks
Fri Oct 05, 2012 7:13 am
Users browsing this forum: No registered users and 84 guests
32,745,441 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
