It is currently Fri Nov 01, 2024 12:23 pm
[ 8 posts ] |
Big O needs parts
He's on the road, now we are just in need of the small stuff.
- wiper arm nuts, the ones that go on the exterior to hold the arms in place. - locking stereo console - hood / cowl area seal (i've never actually seen one)
- anyone hiding a S10 passenger 3pt seat belt in black?
Sun Jan 13, 2013 12:55 pm |
Re: Big O needs parts
On the spring retainer, call Tom's and talk to them about it. They sent me a couple that I bent around my pack. I think I tack welded them together too. Can't be more than a few bucks, but I could not find them on the site.
Extended brake lines, search the forums. I want to say stock ones from '78-79 broncos are long enough for most lifts, but there is a thread I started for this discussion.
Mon Jan 14, 2013 4:38 am |
Colorado75bronc
Ya stock 79 bronco rear works great for lifts upto 6.5"s not sure bout the front, I'm using the 79' bronco rear on the front and back of mine, not the right frame junction for the front, I just made a mount for it
Mon Jan 14, 2013 2:27 pm |
Cool, thanks for the tip on the brake lines
Mon Jan 14, 2013 6:08 pm |
Mon Jan 14, 2013 10:33 pm |
I might have some headlight trim rings for you. Provided I can get these new headlight adjuster screws to work and get my bling, er, billet headlight rings installed. Still have those spring hangers?
Mon Jan 14, 2013 10:34 pm |
Tue Jan 15, 2013 2:13 pm |
Colorado75bronc
I'm sorry I didn't give credit, zac made the bracket, mostly, I attached it, and tweaked it to fit, lol, I had a feeling you'd chime in about that :P
Tue Jan 15, 2013 11:49 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 73 guests |
