It is currently Fri Nov 01, 2024 12:27 pm
[ 8 posts ] |
valentino
drum part
does anyone have the spring under the wheel cylinder?I need it to finish my brake job if you have it call me at 719-282-5967.also does anyone the metal brake line that goes from the wheel cylinder to the rubber part?
Tue Mar 05, 2013 10:26 pm |
Re: drum part
Can't help you on the brake line, but a complete spring kit is something like $7 at most parts stores.
Tue Mar 05, 2013 11:44 pm |
Re: drum part
Wed Mar 06, 2013 12:00 am |
Re: drum part
Odd. I'm sure mine had it. Would probably have been from O'reily.
Wed Mar 06, 2013 1:31 am |
Re: drum part
I remember the kits from AZ and Advanced were both lacking. There were a few old springs I had to reuse.
Wed Mar 06, 2013 3:26 am |
427wrangler
Joined: Sat Nov 03, 2012 7:36 am Posts: 61 Location: Peyton, CO
Re: drum part
I might have what your looking for, I will look through box of brake parts after work this afternoon
Wed Mar 06, 2013 5:24 am |
valentino
Re: drum part
I got one thanks guys and if anyone has one be sure to hold on to them.No one sells them not advance,ford,oreilys or napa only place that sell them new is bronco graveyard http://broncograveyard.com/bronco/i-125 ... pring.html
Thu Mar 07, 2013 10:55 pm |
Re: drum part
Wow, they're proud of that.
Fri Mar 08, 2013 10:02 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 77 guests |
