www.ColoradoClassicBroncos.com - View topic - brake booster stock type d isc disc proportion valve
It is currently Fri Nov 01, 2024 10:30 am
Reply to topic  [ 3 posts ]
Post brake booster stock type d isc disc proportion valve
Looking for a vacuum brake setup. Brackets rod booster. And a disc brake proportion valve
Trei 720-936-0791
Mon Aug 12, 2013 7:02 am
Post Re: brake booster stock type d isc disc proportion valve
You may not need one for disc/disc. Drums operate at much lower PSI, which is why disc/drum setups often need one to keep the rears from locking up. I'd try it without first, then add an adjustable one if needed since you've got a non-standard setup.
Mon Aug 12, 2013 10:22 am
Good point Justin. I thought I would throw it out there if someone had one I would buy it and sell if I don't need ir
Mon Aug 12, 2013 10:26 am
Users browsing this forum: No registered users and 70 guests
32,743,907 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
