It is currently Mon Jul 08, 2024 5:05 am
[ 7 posts ] |
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Emergency brake assembly
Last week I managed I rip the emergency brake pedal assembly off the dash. What can I say? Leg day works.
Anyhow, I need a new one. It doesn't need to be pretty. But is does need to be free of stress cracks in the metal.
Lemme know whatcha got!
Wed Feb 18, 2015 11:15 am |
phyler
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: Emergency brake assembly
Damn, I have one at my dad's place. If you can't source one closer , let me know.
Wed Feb 18, 2015 11:35 am |
Will do. Thanks.
Wed Feb 18, 2015 11:38 am |
I broke mine and used a 79 Cherokee/Wagoneer pedal with very little modification. Bolted right to the firewall.
Wed Feb 18, 2015 6:15 pm |
71 Broncman
Joined: Sun Nov 21, 2010 10:09 am Posts: 132 Location: Woodland Park
I have one you can have but, The tab where it bolts to the dash has been welded back on and one of the studs where it bolts to the firewall is broken off. It did work fine when I took it off . The stud is repairable, it's yours if you want it. Mark.
Wed Feb 18, 2015 8:57 pm |
Think I'm going to pull mine this week and try to fix it. The thing made it 40 years. Maybe I can get another 40 out of it. If that fails, I'll let ya know.
Wed Feb 18, 2015 9:18 pm |
Wed Feb 18, 2015 10:35 pm |
[ 7 posts ] |
