www.ColoradoClassicBroncos.com - View topic - 69 bronco stock drag link and pitman arm needed
It is currently Fri Nov 01, 2024 4:38 am
Reply to topic  [ 8 posts ]
Post 69 bronco stock drag link and pitman arm needed
69 bronco with power steering in need of a stock drag link and Pitman arm to replace this crazy looking setup on the bronco I just purchased. If anyone has something sitting around they may have upgraded from and no longer needs, please post or send me a message, I'd like to pick it up. Thanks,
Alex
1969 Bronco Sport-302-3 Speed Hurst on the Floor-Dana 20 TCase
Dana 30 Front-9" Posi Rear w/ 4:11's
32"s-No Lift
Mon Aug 24, 2015 4:31 pm
Post Re: 69 bronco stock drag link and pitman arm needed
l've got a pair of tie rods ,and a drag link off of a '71...l think they will work on a 69.
no pitman arm though.
the drag link you've got looks like the one that came off my 56 pu.
Mon Aug 24, 2015 5:24 pm
I can go take a look, I think I still have the linkage from my '71 Bronco and a spare pittman arm from a '79 sitting around. If you're interested in a trip down to the Steel City let me know and I'll confirm I still have them before you head down. I had some wandering issues so I can't tell you how good the ball joints are but I think my big issue there was bushings on the trac bar. It all got replaced at the same time along with the worn out steering box.
Mon Aug 24, 2015 8:58 pm
Have a stock pitman from a 72
Tue Aug 25, 2015 7:48 am
If you're interested, I'm contemplating running off a batch of DOM steering linkages.
Tue Aug 25, 2015 8:23 am
Justin,
What does that mean, DOM? Would that replace the factory piece I'm looking for attack to it?
32"s-No Lift
Thu Sep 03, 2015 6:46 am
Drawn Over Mandrel. You use steel tube to replace the tie rod and drag link and use much beefier tie rod ends. Major upgrade in strength.
Thu Sep 03, 2015 7:23 am
VENDOR
VENDOR
I have a almost new (10 miles or less) tie rod and drag link that was on my 66. It's the 3 way adjustable set up that WH sells. PM if your interested. I don't have the pitman arm.
Sat Sep 05, 2015 8:42 am
Profile WWW
Users browsing this forum: No registered users and 73 guests
32,739,989 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
