Some EFI conversion pieces needed
Postby crawlercreations » Tue Nov 24, 2015 5:48 pm
Asking here before I start hitting up the yards this Friday. I am in need of a complete EFI 5.0 wiring harness. Standard mustang stuff to keep it cheap and easy. Not going distributorless on this one. I also need some EFI valve covers, EGR plate between the intake and throttle body, Fuel accumulator, high pressure fuel pump, injector fuel rail, accelerator cable and anything else that may be interestingly helpful. I am also looking for ideas on where to get things like the accumulator without having to spend as much as the bronco vendors want. As nice as it would be to buy from them I would prefer to get it cheaper as this is a present for someone and the price point is very important.
crawlercreations
Re: Some EFI conversion pieces needed
Postby Gunnibronco » Tue Nov 24, 2015 5:53 pm
Don't know if its cheaper, but I found another accumulator option.
http://www.coloradoclassicbroncos.com/v ... ccumulator
I have a 55mm MAF, I'm coming to Denver this weekend and could bring it if you need one.
Postby Justin » Tue Nov 24, 2015 5:54 pm
I think I've got a mustang fuel rail. Yours for the taking.
Postby Eck » Tue Nov 24, 2015 6:01 pm
I've got the orange injectors. I believe they're 19lb. They're junk yard parts but I did replace a lot of the o rings. Let me know if you'd be interested.
Postby B.O.B. » Tue Nov 24, 2015 7:31 pm
I have a new high of pressure in tank walbro pump that will work. Let me know.
B.O.B.
Postby plumbdoctor » Tue Nov 24, 2015 10:04 pm
I have a couple 5.0'harnesses, take your pick, a couple throttle bodies and mass, and I think the block off plate .....
plumbdoctor
Postby RJLougee » Sun Nov 29, 2015 11:21 am
crawlercreations wrote: I am also looking for ideas on where to get things like the accumulator without having to spend as much as the bronco vendors want.
The late '80s, early '90s E150/250 vans with 4.9 EFI (aka 300 inline) six cylinder engines used an accumulator in the stock configuration. It pretty much sits below the driver seat area with the HP pump and filter setup.
HTH, Joe
RJLougee
Return to Bronco Parts Wanted
