Dana 44 gears
Dana 44 gears
Postby cravenbronco » Mon Dec 14, 2015 9:46 pm
I am looking for a complete ring and pinion for the front end it needs to be 4:10 gears. I can replace the bearings if I need to. Thanks everyone happy holidays :-)
cravenbronco
Re: Dana 44 gears
Postby Justin » Mon Dec 14, 2015 10:45 pm
If you need one there is a moderate chance that I've got the correct carrier for those gears. If you're going from stock 3.5 a change of carrier is needed.
Re: Dana 44 gears
Postby cravenbronco » Tue Dec 15, 2015 7:33 am
I believe that it has 3.73 gears in it. Will that carrier work for 4.10 gears ?
cravenbronco
Re: Dana 44 gears
Postby Justin » Tue Dec 15, 2015 8:34 am
No, that's where the carrier break is. 3.73 and down is one carrier, anything above that is another. They also make thicker gearsets to allow you to run higher gears on the carrier you've got.
Re: Dana 44 gears
Postby cravenbronco » Tue Dec 15, 2015 1:35 pm
Ok I understand that thanks for the help. I would like to start looking at pricing and availability. Who or where can I look to find one? What should I put in ? Is any brand better than another ? I like the factory set up it seems to do well but then I think about just upgrading to a air locker.
Thoughts ?
cravenbronco
Re: Dana 44 gears
Postby Justin » Tue Dec 15, 2015 5:32 pm
If you ever think you're going to do a locker, now is the time. 4 wheel parts or any of the EB vendors houses will have the needed gears and setup kit. The vendors might not carry the thicker gears needed if you don't replace the carrier.
Re: Dana 44 gears
Postby mickphatmac » Sat Dec 19, 2015 9:13 am
Images: 14
Re: Dana 44 gears
Postby cravenbronco » Sat Dec 19, 2015 10:10 am
mickphatmac wrote:Are you still looking for this?
http://denver.craigslist.org/pts/5336412775.html
I called and he hasn't responded yet.
cravenbronco
Return to Bronco Parts Wanted
