Steering stuff
Steering stuff
Postby akaFrankCastle » Tue Jan 19, 2016 9:59 pm
Need a drag link, track bar, and stock tie rods for non-inverted Y set up steering linkage. If you're tripping over some parts leftover after a tie rod over conversion, I'll help you get rid of them.
Also need a power steering pump bracket and pump.
Let me know what you've got and what you need for it.
Re: Steering stuff
Postby Colorado75bronc » Tue Jan 19, 2016 10:25 pm
I've got a Saginaw bracket, no pump
Colorado75bronc
Re: Steering stuff
Postby akaFrankCastle » Tue Jan 19, 2016 10:32 pm
Colorado75bronc wrote:I've got a Saginaw bracket, no pump
Well, you've got the hard to find part. Let me know what you need for it.
Is it a late model OEM bracket?
Re: Steering stuff
Postby Kinder » Wed Jan 20, 2016 6:04 am
Your timing is good, just pulled the sag setup from Bubba Smurf, I should also have the track bar.
Re: Steering stuff
Postby ZOSO » Wed Jan 20, 2016 6:30 am
I've got a bunch of 351 parts. Including a sag pump and bracket. intake manifolds, carb, duraspark dist and wires and module, timing chain cover, water pump, pulleys, the whole front dress. Only thing not there unless you can convince Corey to give them is the accessory adaptors. Let me know if there is anything you want. I need the space in my garage.
Re: Steering stuff
Postby TOOLMAN » Wed Jan 20, 2016 7:19 am
I know I have a drag link laying around my shop.
I thought you were trying to get rid of stuff!
TOOLMAN
Re: Steering stuff
Postby akaFrankCastle » Wed Jan 20, 2016 11:21 am
ZOSO wrote:I've got a bunch of 351 parts. Including a sag pump and bracket. intake manifolds, carb, duraspark dist and wires and module, timing chain cover, water pump, pulleys, the whole front dress. Only thing not there unless you can convince Corey to give them is the accessory adaptors. Let me know if there is anything you want. I need the space in my garage.
- yes please
intake manifolds
- have too many of those already
carb
- what kinda carb?
- running points just to get it moving, but maybe interested
timing chain cover
- yes please
water pump
- si
pulleys
- da
front dress
- yup
Tally that up and let me know what I owe you.
Re: Steering stuff
Postby akaFrankCastle » Wed Jan 20, 2016 11:22 am
TOOLMAN wrote:I know I have a drag link laying around my shop.
Ha! Yes, I am downsizing a bunch of stuff. And moving a bunch of stuff. These are just ankle biter things I need to wrap up the Baja.
Re: Steering stuff
Postby ZOSO » Wed Jan 20, 2016 12:04 pm
- yes please
intake manifolds
carb
- what kinda carb?
timing chain cover
- yes please
water pump
- si
pulleys
- da
front dress
- yup
I'll figure out a price and shoot you pics tonight. Carb is an edelbrock 1406 650cfm electric choke. I have 2 edelbrock performer 351 intakes.
Re: Steering stuff
Postby akaFrankCastle » Wed Jan 20, 2016 12:47 pm
- yes please
intake manifolds
carb
- what kinda carb?
timing chain cover
- yes please
water pump
- si
pulleys
- da
front dress
- yup
Already have an Edelbrock performer for this motor, so I'm good there. my other 351w is getting an OEM ford 4 barrel intake from a 69 cougar.
Re: Steering stuff
Postby Justin » Wed Jan 20, 2016 7:43 pm
What, you don't need a factory 351w intake that's really, really blue?
Re: Steering stuff
Postby akaFrankCastle » Wed Jan 20, 2016 7:53 pm
Justin wrote:What, you don't need a factory 351w intake that's really, really blue?
Nope. I currently have just enough intakes. But thanks.
that EGR port on the intake would have been a deal breaker anyhow.
Re: Steering stuff
Postby akaFrankCastle » Wed Jan 20, 2016 8:49 pm
Steering stuff
Postby Eck » Wed Jan 20, 2016 9:03 pm
Frank- I might have an extra linkage with tie rod and drag link. I'm out of town but I'll check and send a picture on Friday if I do.
Re: Steering stuff
Postby akaFrankCastle » Thu Jan 21, 2016 4:22 am
Eck wrote:Frank- I might have an extra linkage with tie rod and drag link. I'm out of town but I'll check and send a picture on Friday if I do.
Thanks
Re: Steering stuff
Postby Colorado75bronc » Thu Jan 21, 2016 8:11 am
It's a wildhorses bracket, $25
Colorado75bronc
Re: Steering stuff
Postby akaFrankCastle » Thu Jan 21, 2016 8:34 am
Colorado75bronc wrote:It's a wildhorses bracket, $25
Done.
Re: Steering stuff
Postby Colorado75bronc » Fri Jan 22, 2016 12:47 am
Cool, are you going to be around Friday/tomorrow night around 7-7:30? I may be able to get it and the old free02 over to you in one shot.
Colorado75bronc
Re: Steering stuff
Postby akaFrankCastle » Fri Jan 22, 2016 6:21 am
Colorado75bronc wrote:Cool, are you going to be around Friday/tomorrow night around 7-7:30? I may be able to get it and the old free02 over to you in one shot.
I'll be out of the house for most of the day Saturday. Aside from that I should be around the entire weekend.
Re: Steering stuff
Postby Colorado75bronc » Fri Jan 22, 2016 8:47 pm
Sunday morning work then? And if so any particular time?
Colorado75bronc
Re: Steering stuff
Postby akaFrankCastle » Fri Jan 22, 2016 10:03 pm
Colorado75bronc wrote:Sunday morning work then? And if so any particular time?
Play it by ear. Things are moving rather quickly right now. (Closing date moving up.)
Re: Steering stuff
Postby Colorado75bronc » Fri Jan 22, 2016 11:55 pm
OK sounds good, I'll call you Sunday morning
Colorado75bronc
Re: Steering stuff
Postby akaFrankCastle » Sun Feb 07, 2016 7:07 pm
Any luck?
Re: Steering stuff
Postby Eck » Mon Feb 08, 2016 9:16 am
Any luck?
I sent you pics and you said it wouldn't work because it was a '66 linkage.
Re: Steering stuff
Postby akaFrankCastle » Mon Feb 08, 2016 10:37 am
Any luck?
Ah yes! Sorry. My brain is in a thousand places right now.
Re: Steering stuff
Postby Gunnibronco » Mon Feb 08, 2016 12:41 pm
Any luck?
Can you send me pics?
What do you want for it? It wouldn't hurt to have extras around, not sure how my 66 steers.
Chad
Re: Steering stuff
Postby TOOLMAN » Tue Feb 09, 2016 7:41 am
I'm pretty sure I have a drag link. We could do a deal...I kind of want that floor you have.
TOOLMAN
Re: Steering stuff
Postby akaFrankCastle » Tue Feb 09, 2016 8:24 am
Are you referencing the rear cargo bed floor? If so, it's already sold.
Re: Steering stuff
Postby TOOLMAN » Tue Feb 09, 2016 10:02 am
Dammit! Anyway, I think I have a drag link....
TOOLMAN
Return to Bronco Parts Wanted
