Shift collar for 3 speed needed
Postby landshark » Wed Apr 06, 2016 11:10 am
Turns out everything in the column is good, but I could use a decent shift collar for a 3 speed if anyone has one in Denver? if not I can try to use the one i have but the hole the pin goes through is pretty wallowed out.
Re: Steering Column 3 Speed rebuild parts
Postby plumbdoctor » Wed Apr 06, 2016 8:40 pm
I have a 3 speed column that you could use for some parts
plumbdoctor
Postby landshark » Wed Apr 06, 2016 8:44 pm
plumbdoctor wrote:I have a 3 speed column that you could use for some parts
that would be great, i will text you tomorrow if your around.
Return to Bronco Parts Wanted
