Brake pedal for Automatic Transmission
Postby mickphatmac » Tue Mar 06, 2018 11:10 am
Looking to swap out my Clutch and Brake pedal for the Brake pedal only...
I assume they are different, or can I just remove the Clutch Pedal and have the same thing?
If they're different, I'd rather have the Automatic instead of a chopped version...if ya know what I'm sayin'!?
Images: 14
Re: Brake pedal for Automatic Transmission
Postby Kinder » Tue Mar 06, 2018 11:27 am
You can just pull the clutch pedal and leave the brake pedal. If my memory is right the ‘76 & ‘77 had larger brake pedals, but hard to find.
Postby 71 Broncman » Tue Mar 06, 2018 11:56 am
I pulled the clutch pedal when I converted mine. I also saved all the clutch linkage parts, bell housing, and flywheel and gave them to one of the members that needed them for a project he was working on.
Mark.
71 Broncman
Postby mickphatmac » Tue Mar 06, 2018 1:29 pm
OK Cool!
I'll just ditch the clutch pedal then!
Thank You!
Images: 14
Postby Eck » Tue Mar 06, 2018 1:51 pm
Kirk is correct-- in 76-77 they changed the brake pedal assembly for automatics for the power brakes to a wider pedal-- you'd be looking at close to $200 to buy one online (and I know how cheap you are!!). I don't think it is worth it unless you came across one (I also know you are a craigslist mastermind)!
Postby mickphatmac » Tue Mar 06, 2018 4:13 pm
Eck wrote:...and I know how cheap you are!! I also know you are a craigslist mastermind!
LOLOLOLOLOLOLOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :laughing2: shrug :laughing2:
Images: 14
Postby D&D72 » Tue Mar 06, 2018 8:18 pm
Put a spacer in where the clutch pedal comes out.
D&D72
Postby mickphatmac » Tue Mar 06, 2018 9:17 pm
D&D72 wrote:Put a spacer in where the clutch pedal comes out.
Gotcha! Good info!
Images: 14
Return to Bronco Parts Wanted
Users browsing this forum: Google [Bot] and 3 guests
