Stock Fan Shroud
Stock Fan Shroud
Postby BroncoRaider » Fri Aug 17, 2018 7:39 am
My stock fan shroud cracked. Looking for a replacement. Anyone have a shroud on their shelf they want to get rid of? I’ll be at breakfast tomorrow. Thanks.
Tim
BroncoRaider
Re: Stock Fan Shroud
Postby Justin » Fri Aug 17, 2018 9:28 am
I think I have a steel one. I'll look tonight
Postby D&D72 » Fri Aug 17, 2018 9:40 am
Bring that shroud with you Tim, I can probably fix it like new ....
D&D72
Postby Kinder » Fri Aug 17, 2018 1:20 pm
I have one on the shelf I’ll give you if the above options don’t work out. I’ll take the broken one in trade as I need one to modify for BSD.
Postby BroncoRaider » Mon Aug 20, 2018 5:33 am
Thanks guys. Kirk, I’ve got a couple of options that I’m going to try, but I will save mine for you if you’d rather not cut up a good one.
BroncoRaider
Postby Kinder » Mon Aug 20, 2018 8:03 am
BroncoRaider wrote:Thanks guys. Kirk, I’ve got a couple of options that I’m going to try, but I will save mine for you if you’d rather not cut up a good one.
Sounds good.
Return to Bronco Parts Wanted
