mickphatmac wrote:Should be open at the bottom so you can bolt in the torque converter
I’m missing the lower part of this one
mickphatmac wrote:I don’t know if that will fit your engine or not you’re more than welcome to it if you know someone heading South from North?
It was on one of my C4’s for a 302
pgilbeau wrote:Pretty sure this one is actually from a manual after seeing the other pics. What year was the 351W from?
Needs to be 164 tooth flexplate version.ZOSO wrote:Any auto small block would work. Chris the one you posted is 351m/400/429/460
Viperwolf1 wrote:Needs to be 164 tooth flexplate version.ZOSO wrote:Any auto small block would work. Chris the one you posted is 351m/400/429/460
Yes. A smaller flexplate needs to have the starter moved in so it can still contact the teeth properly. You would notice it if you tried to put a small (157 tooth or less) block plate into a 164 tooth bell. The starter bolt holes won't quite line up.ZOSO wrote:Viperwolf1 wrote:Needs to be 164 tooth flexplate version.ZOSO wrote:Any auto small block would work. Chris the one you posted is 351m/400/429/460
Please explain? Since the bolt pattern is the same how does this plate make a difference? Is the starter in a different location?
Big heavy vehicles got the bigger flexplate. Mustang's in the 60-70's were typically 157 tooth and that even got smaller during the pinto era.ZOSO wrote:Makes sense. So is there specific vehicles or years that are 157? or is it a mix?
