Postby Rox Crusher » Mon Aug 31, 2020 6:39 pm
Will the hovercraft be making the journey to BV ?
Postby Justin » Mon Aug 31, 2020 6:48 pm
Its a goal. If I can figure out why the tcase won't shift the rear shaft out of neutral the chances improve dramatically. Put in the jbfab adjustable detent kit, so it may be as easy as backing off the spring tension.
Postby Justin » Tue Sep 01, 2020 9:25 pm
Finished up the shifter mount for the t-case and doubler. Image
Postby Jesus_man » Wed Sep 02, 2020 7:05 am
That is an interesting piece! Looking forward to seeing it in action.
Postby Justin » Thu Sep 03, 2020 5:57 pm
Sort of wishing my lockers were cable actuated, just so I could have more shifters. Image
Postby Eck » Thu Sep 03, 2020 6:09 pm
You purchase that transmission shifter? Do you have the original ZF5 shifter you’d want to part with?
Postby Justin » Thu Sep 03, 2020 6:18 pm
I've got the stock one, but no no knob for it. Yours for the taking. I'm using the JB Fab one.
Postby Eck » Thu Sep 03, 2020 6:20 pm
Justin wrote:I've got the stock one, but no no knob for it. Yours for the taking. I'm using the JB Fab one.
Perfect. I want to try something but don’t want to do it with the one I’ve got on mine just in case it doesn’t work.
Postby Justin » Thu Sep 03, 2020 6:21 pm
I'm working from home, so I'm around most of the time.
Postby Kinder » Fri Sep 04, 2020 8:04 pm
Justin wrote:Sort of wishing my lockers were cable actuated, just so I could have more shifters. Image
Those look great.
Postby Dukietown » Mon Sep 07, 2020 8:57 am
I really like your anti-theft setup! thumbs up
Dukietown
Postby Justin » Mon Sep 07, 2020 3:43 pm
So, this happened. Image
Postby landshark » Mon Sep 07, 2020 4:19 pm
You left it in neutral and it rolled into the street?
I kid, looks great can’t wait to see it in person!
Postby Justin » Mon Sep 07, 2020 4:20 pm
Shhhh, don't tell!
Postby Eck » Mon Sep 07, 2020 4:20 pm
Saaaawwwweeeettt!
Postby Strike2 » Mon Sep 07, 2020 6:30 pm
Congratulations I also can’t wait to see it in person thumbs up
Strike2
Postby Rox Crusher » Mon Sep 07, 2020 6:44 pm
That is so excellent !
Postby Justin » Thu Dec 31, 2020 10:16 pm
Got a rear sear I've had stashed forever recovered to match the fronts. I think it's Rox's old one. Pretty happy with how it came out given that I've never done upholstery before.
Postby Justin » Mon Feb 08, 2021 9:06 am
Got a little work done on the cage extension. Trying to decide if I'm going to leave the existing kickers to the wheel wells or run a new bar to triangulation. Image
Postby Digger » Mon Feb 08, 2021 4:41 pm
I vote new bar.
Looks great!
Postby Gunnibronco » Mon Feb 08, 2021 8:57 pm
Looks good, must be "Roll Cage Season"
Is that 2"? Looks beefy compared to what I'm working with.
Postby Justin » Mon Feb 08, 2021 9:18 pm
Yep. Would have done 1.75, but the existing cage is mostly 2".
Postby Justin » Sat Apr 03, 2021 4:06 pm
Making progress on the cage. Also got the viperwolf special sauce power steering pump installed. Old one didn't flow enough to power hydroboost, 4x4x2 and ram assist. If there's still issues, the hydroboost unit will be going out to Vanco to be rebuilt and ported for better flow.
Postby Rox Crusher » Sun Apr 04, 2021 4:06 am
You will like that pump
Postby Kinder » Sun Apr 04, 2021 6:18 pm
Ha, what diameter is that blue hose, over an 1”!
Postby Justin » Sun Apr 04, 2021 6:27 pm
Kirk, 12AN. Jeff, I'm hoping so! It'll be a big improvement no matter what
Postby Digger » Sun Apr 04, 2021 8:36 pm
What reservoir is that?
Postby Justin » Sun Apr 04, 2021 9:07 pm
Diesel Excursion. I can't remember the year.
Postby Rox Crusher » Mon Apr 05, 2021 12:13 am
Digger wrote:What reservoir is that?
I have one if you’d like it.
Postby Digger » Mon Apr 05, 2021 12:44 pm
It looks almost identical to the 03 Super Duty unit I'm working with.
