www.ColoradoClassicBroncos.com - View topic - How to get donor Mustang off trailer
It is currently Sun Nov 24, 2024 4:58 am
Reply to topic  [ 62 posts ]  Go to page 1, 2, 3  Next
Post How to get donor Mustang off trailer
I found a great donor. 2019 Bullit. It is already on a trailer. All four wheels are trashed.
Any helpful ideas on how to get it off trailer and into the garage?
I also need recommendations for dollies to move it around the garage while I am dismantling it.Image
Sent from my SM-G975U using Tapatalk
1966 Bronco - 408 roller cam, Explorer serpentine, NV3550 5spd, hydroboost, 35s, 4.56 gears
Thu Oct 29, 2020 3:44 pm
Post Re: How to get donor Mustang off trailer
I love where this is headed.
Thu Oct 29, 2020 4:25 pm
Crested Butte
Thu Oct 29, 2020 4:40 pm
I have had good luck with the Harbor Freight 1500lb Dollies.
https://www.harborfreight.com/2-piece-1 ... icle+dolly
Guessing it was put on the trailer with a fork lift. Does your trailer have ramps? If so I am sure you can find some way to get it down the ramps.
Thu Oct 29, 2020 4:46 pm
Those dolly's should make it much easier to move once it is on the slab.
His trailer has ramps. They are heavy duty ladder style.
Thu Oct 29, 2020 6:09 pm
I'd leave it on the trailer and cut away everything that isn't engine. If you take it off the trailer you'll need to find a way to get it back on when you're done.
Thu Oct 29, 2020 6:37 pm
Good idea about leaving it on the trailer.
Unfortunately the trailer is not mine. It belongs to my friend that is giving the Mustang to me, and he needs it for work.
Also, it has a lot of cool salvageable parts. Trick Brembo calipers and a really nice stereo that will work in Dad's 2019 GT that has an entry level stereo.
Thu Oct 29, 2020 7:38 pm
I've done different things in the past to get salvage vehicles on and off the trailer, I usually always try and make sure they roll. That looks like the best it could get is the rear rolling. Don't know if you have access to one but I have used the winch on my Bronco to pull a vehicle off my trailer and down the ramps. Maybe if you put something over the ramps to make it smooth it could be dragged off.
Thu Oct 29, 2020 10:18 pm
how about hiring a tilt bed tow truck
drag it onto the tilt bed
have the tilt bed drop it where it needs to be
Fri Oct 30, 2020 6:49 am
Truck with a strap if both rears will still roll but probably mess up the trailer deck. Maybe some kind of skid plate (4’x8’ sheet of steel?) under front and then pull it off.
Fri Oct 30, 2020 8:40 am
Well I think the obvious answer is Forklift...But where to get one!???
Fri Oct 30, 2020 9:39 am
Fri Oct 30, 2020 9:41 am
Backhoe from rental place. Put it where you want it.
Owned my 1972 since 1985
Canon City, Co
Fri Oct 30, 2020 11:00 am
Deciding on which BroncoImageImage
Fri Oct 30, 2020 11:24 am
BOTH
Canon City, Co
Fri Oct 30, 2020 4:00 pm
After seeing another post similar to this, i have been thinking you could strap some type of a ski (old snowboard?) to each corner that doesnt roll and slide it off. Might work better than just dragging.
Fri Oct 30, 2020 6:21 pm
Fri Oct 30, 2020 8:51 pm
Finally got it in the garage.
*Harbor freight dolly helped a lot.
*Hooked a winch to the tongue of the trailer and a pulley to the ramps and used that to pull it off.
*2x12s on the ramps.
*My wife's explorer winter wheels fit on the rear axle.
Thanks for the ideas.Image
Sat Oct 31, 2020 8:02 pm
Glad you got it off the trailer and in the garage. Now the real work begins!
Sun Nov 01, 2020 1:06 pm
Sun Nov 01, 2020 4:29 pm
That was last winters project.
Sun Nov 01, 2020 5:22 pm
Subscribed!!
Tue Nov 03, 2020 9:29 am
Good news. Charged the battery and it started instantly!!!
Tue Nov 03, 2020 7:39 pm
Big Win! Now to make it all talk from under the hood of one of those broncos!
Tue Nov 03, 2020 8:08 pm
Making so.e progress on getting things stripped off.ImageImageImage
Fri Nov 13, 2020 7:58 pm
Progress! I like it! There's a stripper joke in there somewhere, but I'm too tired to find it.
Fri Nov 13, 2020 10:05 pm
Decisions need to be made.
My son's 96 Bronco has an old and tired 302/5.0. 5 speed manual.
My 66 has an almost new 408 stroker, roller cam, AFR heads, Carburetor. 5 speed - NV3550/ Dana 20.
Option 1: Put the Coyote in Brock's Bronco.
Option 2: Put the Coyote in my Bronco and the 408 into my son's.
Option 3: Open for ideas.Image
Sat Nov 14, 2020 5:37 pm
That's a tough call! It would be really sweet in either, but much more work to perform two motor swaps!
Mon Nov 16, 2020 10:10 am
#2 please and ThankYou
Mon Nov 16, 2020 6:10 pm
Almost done stripping the donor.ImageImage
Sat Nov 21, 2020 6:45 pm
32,991,170 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
