2x5 vs. tube sliders
Postby Justin » Sun Dec 13, 2020 6:22 pm
Going to be cutting off the rockers and installing rock sliders soon. Any experienced suggestions on doing 2x6 tube vs. 2x4 with a 1.5" tube rub rail?
Re: 2x5 vs. tube sliders
Postby Mitche11 » Sun Dec 13, 2020 9:30 pm
I used 2x6 tubing because I liked the strength, support where rollbar attaches and i thought it added a little protection from a possible side impact. Drawbacks are that it pinches the space needed for the 2nd fuel tank and it can leave your rig looking like it’s wearing too short a skirt (if there is such a thing). I welded up a 2x2 tube below the 2x6 to give the body the needed size there. This then left the body level with the bottom of the frame.
72 Bronco Sport, 5.8 EFI, NV3550
Mitche11
Postby Jesus_man » Mon Jan 04, 2021 9:53 am
I am running what I recall as being 2x3 laying flat and the same behind it in a vertical position effectively creating an L shape which ends up being 5" W x 3" tall. I did this because mine are only welded to the body, which I think is a mistake. But they are very strong and have had the whole weight of the bronco on them. The body just can't take much of that.
Here is the best photo I could find:
Postby ZOSO » Mon Jan 04, 2021 4:28 pm
Mine are just a 2x3x1/4" with legs bolted to the frame. I built the same style on my 79 out of 2x2. Being frame mounted it keeps the stress and abuse off the already weak body after you cut the rockers off. I have tested them on chinamans gulch with zero issues. Now the low hanging gas tank thats a different story.
