It is currently Tue May 21, 2024 10:38 am
Will the hovercraft be making the journey to BV ?
Mon Aug 31, 2020 7:39 pm |
Its a goal. If I can figure out why the tcase won't shift the rear shaft out of neutral the chances improve dramatically. Put in the jbfab adjustable detent kit, so it may be as easy as backing off the spring tension.
Mon Aug 31, 2020 7:48 pm |
Finished up the shifter mount for the t-case and doubler.
Tue Sep 01, 2020 10:25 pm |
That is an interesting piece! Looking forward to seeing it in action.
Wed Sep 02, 2020 8:05 am |
Sort of wishing my lockers were cable actuated, just so I could have more shifters.
Thu Sep 03, 2020 6:57 pm |
You purchase that transmission shifter? Do you have the original ZF5 shifter you’d want to part with?
Thu Sep 03, 2020 7:09 pm |
I've got the stock one, but no no knob for it. Yours for the taking. I'm using the JB Fab one.
Thu Sep 03, 2020 7:18 pm |
Thu Sep 03, 2020 7:20 pm |
I'm working from home, so I'm around most of the time.
Thu Sep 03, 2020 7:21 pm |
Fri Sep 04, 2020 9:04 pm |
Dukietown
Mon Sep 07, 2020 9:57 am |
So, this happened.
Mon Sep 07, 2020 4:43 pm |
You left it in neutral and it rolled into the street?
I kid, looks great can’t wait to see it in person!
Mon Sep 07, 2020 5:19 pm |
Shhhh, don't tell!
Mon Sep 07, 2020 5:20 pm |
Saaaawwwweeeettt!
Strike2
Congratulations I also can’t wait to see it in person
Mon Sep 07, 2020 7:30 pm |
That is so excellent !
Mon Sep 07, 2020 7:44 pm |
Got a rear sear I've had stashed forever recovered to match the fronts. I think it's Rox's old one. Pretty happy with how it came out given that I've never done upholstery before.
Thu Dec 31, 2020 11:16 pm |
Got a little work done on the cage extension. Trying to decide if I'm going to leave the existing kickers to the wheel wells or run a new bar to triangulation.
Mon Feb 08, 2021 10:06 am |
I vote new bar.
Looks great!
Mon Feb 08, 2021 5:41 pm |
Looks good, must be "Roll Cage Season"
Is that 2"? Looks beefy compared to what I'm working with.
Mon Feb 08, 2021 9:57 pm |
Yep. Would have done 1.75, but the existing cage is mostly 2".
Mon Feb 08, 2021 10:18 pm |
Making progress on the cage. Also got the viperwolf special sauce power steering pump installed. Old one didn't flow enough to power hydroboost, 4x4x2 and ram assist. If there's still issues, the hydroboost unit will be going out to Vanco to be rebuilt and ported for better flow.
Sat Apr 03, 2021 5:06 pm |
You will like that pump
Sun Apr 04, 2021 5:06 am |
Ha, what diameter is that blue hose, over an 1”!
Sun Apr 04, 2021 7:18 pm |
Kirk, 12AN. Jeff, I'm hoping so! It'll be a big improvement no matter what
Sun Apr 04, 2021 7:27 pm |
What reservoir is that?
Sun Apr 04, 2021 9:36 pm |
Diesel Excursion. I can't remember the year.
Sun Apr 04, 2021 10:07 pm |
Mon Apr 05, 2021 1:13 am |
It looks almost identical to the 03 Super Duty unit I'm working with.
Mon Apr 05, 2021 1:44 pm |
