Machine shop North of Denver
Postby wileec » Sun Jan 10, 2021 8:53 am
I just got my Bilstein 7100s WOOT!. The only problem I have at the moment is the my rear upper mounts are stud style 5/8 shank bolts. See picture. and the Bilstein have 1/2' heim joints. I have been having a bear of a time finding this stud with the smooth part being 1/2" to match the hiems on the Bilsteins. Does anyone know of a machine shop kind of up north, I am in Erie, That would take on a small job and turn the 5/8 section down to 1/2 for me for not a stupid amount of cash.
I would also accept other options and creativity.
Isn't 27 years classic?
wileec
Re: Machine shop North of Denver
Postby landshark » Mon Jan 11, 2021 8:50 am
You can swap out the hiems in the bilstiens with bushings that should work. I think they are 5/8 eyelets. Did so on mine. Let me see if I can find the part number to be sure
Postby wileec » Mon Jan 11, 2021 10:00 am
landshark wrote:You can swap out the hiems in the bilstiens with bushings that should work. I think they are 5/8 eyelets. Did so on mine. Let me see if I can find the part number to be sure
That is a different thought. As I research it I see that many people have changed to a bushing instead? If you have a part number that would be great.
wileec
Postby landshark » Mon Jan 11, 2021 3:34 pm
I think these are them -
Prothane 19-920-BL
https://www.amazon.com/gp/product/B003A ... UTF8&psc=1
Postby wileec » Tue Jan 12, 2021 1:57 pm
Perfect Chris. Did you use it without the sleeve then? It looks lie that sleeve is 1/2 Thanks. Once I get all the pieces I will get out and test. I hope my valving is good.
wileec
Postby Digger » Tue Jan 12, 2021 11:28 pm
I would 2nd what Chris said. I did the same thing.
Postby Jesus_man » Wed Jan 13, 2021 9:14 am
Having some extra vibration isolation is a good thing.
Here is a link to Prothane's catalog. Skip down to page 13 to see the shock bushings and pick your poison.
https://prothane.com/wp-content/uploads ... -11-19.pdf
Postby landshark » Wed Jan 13, 2021 10:13 am
wileec wrote:Perfect Chris. Did you use it without the sleeve then? It looks lie that sleeve is 1/2 Thanks. Once I get all the pieces I will get out and test. I hope my valving is good.
no sleeve
