Hydroboost seal
Hydroboost seal
Postby Eck » Wed Jan 13, 2021 11:15 am
I need the main seal for the main piston. I have ordered a few but USPS has it stuck somewhere in their system.
Does anyone have one local that I could buy or use and then replace when mine come in?
Long shot I’m sure.
Re: Hydroboost seal
Postby BroncoRaider » Wed Jan 13, 2021 12:00 pm
Ive got a rebuild kit. If it’s in there, we can make that work.
BroncoRaider
Re: Hydroboost seal
Postby Eck » Wed Jan 13, 2021 12:44 pm
BroncoRaider wrote:Ive got a rebuild kit. If it’s in there, we can make that work.
That is awesome-- it should be in there but it is the larger round seal in this picture. If you are around later this afternoon ( after 4:30-- I could swing by and grab it)! Thanks!
Re: Hydroboost seal
Postby kbank6 » Thu Jan 14, 2021 6:58 pm
if it's not in the kit you could try Rocket Seals in Den.
kbank6
Re: Hydroboost seal
Postby Eck » Thu Jan 14, 2021 7:47 pm
kbank6 wrote:if it's not in the kit you could try Rocket Seals in Den.
Tim had me covered but thanks for the local recommendation. I was hoping to have it all back together and tested today but I snapped an AN fitting tightening everything up so now I wait for the mail system once again.
Re: Hydroboost seal
Postby landshark » Thu Jan 14, 2021 10:23 pm
What an fitting do you need? I might have it
Re: Hydroboost seal
Postby Eck » Thu Jan 14, 2021 10:25 pm
landshark wrote:What an fitting do you need? I might have it
The 5/16 24 o ring to 6 AN for the hydroboost low pressure. I believe it’s also called the spittier. It is the port that normally has the hose barb fitting.
Re: Hydroboost seal
Postby Justin » Sat Jan 16, 2021 11:14 am
Chris, where did you source your fitting and was it decent quality?
Hydroboost seal
Postby landshark » Sun Jan 17, 2021 9:54 am
Justin wrote:Chris, where did you source your fitting and was it decent quality?
I did not have one. Last time I bought them I think it was off ebay
Re: Hydroboost seal
Postby Eck » Sun Jan 17, 2021 10:38 am
labwork 6 an x 5/16-24 o Ring hydroboost spittier/Return Port https://www.amazon.com/dp/B07TWJVX7C/re ... UTF8&psc=1
This is what I just got. Seems like good enough quality- just don’t over tighten this fitting since it is so small and is only low pressure anyways.
Re: Hydroboost seal
Postby Justin » Sun Jan 17, 2021 10:47 am
Cool, thanks. I'll order that labwork one. Hydratech sells on, but its 2x the price and they've got warnings all over their site to only torque to 10 ft/lbs and hold it while you attach a hose.
Return to Bronco Parts Wanted
