Correct and that was my assumption as well. The MC I have had one that you added for power brakes vs manual brakes but when I added the 1/2” spacer- it obviously created a 1/2” lag. I haven’t been able to find anything off the shelf yet and it seems like the clocking bracket is a fairly common thing people are doing so I’m curious. Does it make more sense to have a longer rod on the hydroboost side or the master cylinder side?Kinder wrote:Is the spacer between the MC and the booster? If yes then you’ll likely need to add something to take up the space that was created. Lengthening the rod from the pedal to the booster won’t solve this problem since it’s the rod out of the booster that isn’t engaging the MC correctly. I’m not sure if there is an off the shelf solution, I’ll look for something to link to.
Looks to be a 1” bore.phyler wrote:Do you know what size bore your master cylinder has? That can affect pedal feel.
I wouldn't think that would be super stiff then. I've heard of it happening with the 1.25" bore.Eck wrote:Looks to be a 1” bore.phyler wrote:Do you know what size bore your master cylinder has? That can affect pedal feel.
This is what I bought. https://swperformanceparts.com/product/ ... B8QAvD_BwE
