Jesus_man wrote:We are all very excited to see your creation come to life!!!
Digger wrote:I installed the new column and bolted up the steering wheel adapter only to discover a fitment issue where the adapter sat too low on the shaft and was dragging on the horn contact post. I pulled the board and shorted the post slightly.
Jesus_man wrote:Digger wrote:I installed the new column and bolted up the steering wheel adapter only to discover a fitment issue where the adapter sat too low on the shaft and was dragging on the horn contact post. I pulled the board and shorted the post slightly.
That could have been interesting on first startup! Horn blaring!!
This all looks amazing! One thing you may consider is isolating your intake tube from the core support. I would bet it will rattle around inside that hole.
TOOLMAN wrote:You're such a dick....(wink wink).
For the record, I say this when I play golf with friends that strike the ball especially well. It's truly a compliment.
