It is currently Fri Nov 22, 2024 5:55 pm
Re: muffle that noise!!
my exhaust I just pulled off was all the way back against the bumper. turned and went out the side. was tucked up real close to the body up above the the bumper low point. I'll send you some pics since they are on my phone.
Tue Jan 05, 2021 5:58 pm |
Tue Jan 05, 2021 8:19 pm |
TOOLMAN
Wed Jan 06, 2021 8:38 pm |
TOOLMAN
I can do better pictures when I can get it out of the garage. Granted, I haven't done any really tough trails since I did it, but I haven't dinged it yet. I don't think Chris has either. And his has been like that for a lot longer. It kind of reminds me of the tucked dual exhaust of the big block '60s Galaxies...
Wed Jan 06, 2021 8:53 pm |
Thanks, that is about where mine used to be. It might be my only option.
Wed Jan 06, 2021 11:20 pm |
Toolman, that is along the lines I was thinking, but I think they need to be even higher. I'll bet any trail rated 5 of 10 or higher will have a high potential of damaging that. But with a fuel tank that takes up all the space between the frame rails, it makes it tougher to route. There is, however, a third option:
Thu Jan 07, 2021 9:44 am |
Hers mine, obviously hasn’t been an issue as there are so many other things to smash before i hit the exhaust. It’s 3” I believe and not many issues with fumes if I keep both windows closed or open both when I run the enclosed top. Gets a little bad when I have one window open and enclosed top closed up.
Thu Jan 07, 2021 10:04 am |
Well I finally finished my exhaust completely. Im happy overall with my muffler choice. Routing sucked around the 4 link. It is as loud cruising as it is at idle. I can actually hear the stereo now going down the highway. Muffler is a Flowtec warlock turbo muffler. https://www.youtube.com/watch?v=gqvLqUwLacw
Sat Mar 13, 2021 8:50 am |
Sounds good!
Sun Mar 14, 2021 12:16 am |
Looks and sounds good !
Sun Mar 14, 2021 2:59 pm |
That is a good noise! We need a drive-by video!
Mon Mar 15, 2021 8:55 am |
