Sudden electrical wierdness
Postby laffycaffi » Thu Mar 18, 2021 5:55 pm
Suddenly my gas meter stopped working. My passenger tail light won’t turn off, my driver side brake light won’t work, unless I’ve turned my left turn signal on - that activates my drivers side brake light.
Any ideas?
laffycaffi
Re: Sudden electrical wierdness
Postby phyler » Thu Mar 18, 2021 6:23 pm
With any electrical weirdness, start making sure your grounds are good. I'd look at a wiring diagram and see what all those have in common as well. Might be the plug under the hood right in front of the driver came a bit loose?
CCB Admin
Postby Viperwolf1 » Thu Mar 18, 2021 7:50 pm
The wiring harness going back along the frame has a problem. If you have exhaust running along the drivers side it's somewhat common to melt those wires.
Postby Kinder » Fri Mar 19, 2021 4:53 pm
I’ll add that since you just did a bunch of exhaust work you may have jarred the wires and made an almost problem a real problem. Look along the harness from the firewall back and see if the wrap (electrical tape likely) looks nicked or otherwise damaged and start there.
Postby laffycaffi » Mon Mar 22, 2021 1:05 pm
Here’s a video of the wiring along the frame. Not really sure what I’m looking for. Seems fine to me? https://youtu.be/3Xvg5lL3tgk
And here are some pics.
laffycaffi
Postby laffycaffi » Mon Mar 22, 2021 4:20 pm
Good news. I cleaned the grounds at the brake lights and problem solved! But the fuel meter still nothing.
laffycaffi
Postby phyler » Mon Mar 22, 2021 5:06 pm
laffycaffi wrote:Good news. I cleaned the grounds at the brake lights and problem solved! But the fuel meter still nothing.
Check the ground. [emoji16] It's back by the fuel tank. Easy for it to get crudded up. Had that happen on mine. Cleaned and my gas gauge has been consistent since.
CCB Admin
Postby Eck » Mon Mar 22, 2021 7:14 pm
And fuel gauges only work in 30% of Broncos so don’t beat yourself up too much if it doesn’t work!!
Postby phyler » Mon Mar 22, 2021 7:15 pm
Eck wrote:And fuel gauges only work in 30% of Broncos so don’t beat yourself up too much if it doesn’t work!!
Too true. Most that do work are off by 1/4 tank as well (reading 3/4 when full).
CCB Admin
Postby Eck » Mon Mar 22, 2021 7:19 pm
Guilty- and I replaced the wiring and sending unit.
Postby laffycaffi » Tue Mar 23, 2021 4:20 am
Ha well that’s good to know. Did replacing the sending unit solve it for you?
laffycaffi
Postby Eck » Tue Mar 23, 2021 8:34 am
laffycaffi wrote:Ha well that’s good to know. Did replacing the sending unit solve it for you?
Sort of. My old one did not work at all and so I replaced it with a new one. However-- even that one isn't accurate like modern vehicles. At FULL it shows about 3/4 fill and when I am on E-- I know I still have around 1/4 tank. So it works well enough to use it so I never get stranded...
