Suddenly my gas meter stopped working. My passenger tail light won’t turn off, my driver side brake light won’t work, unless I’ve turned my left turn signal on - that activates my drivers side brake light.
Any ideas?
Check the ground. [emoji16] It's back by the fuel tank. Easy for it to get crudded up. Had that happen on mine. Cleaned and my gas gauge has been consistent since.laffycaffi wrote:Good news. I cleaned the grounds at the brake lights and problem solved! But the fuel meter still nothing.
Too true. Most that do work are off by 1/4 tank as well (reading 3/4 when full).Eck wrote:And fuel gauges only work in 30% of Broncos so don’t beat yourself up too much if it doesn’t work!!
Guilty- and I replaced the wiring and sending unit.phyler wrote:Too true. Most that do work are off by 1/4 tank as well (reading 3/4 when full).Eck wrote:And fuel gauges only work in 30% of Broncos so don’t beat yourself up too much if it doesn’t work!!
laffycaffi wrote:Ha well that’s good to know. Did replacing the sending unit solve it for you?
