pgilbeau wrote:I had a similar issue after my swap to a ZF-5 and trip to Moab, seemed like it leaked more when it warmed up. My leak was on the tail housing, it turns out the place I bought if from tried to weld a crack up. You could see where it had been welded and ground down. I ended up pulling it and got it warrantied. I finished that trip to Moab with the leak and pulled the ZF-5 and Atlas when I got back. With the time crunch to the Rubicon I would probably evaluate how bad the leak is and decide. To me the other issue is that there really is no easy way to fill the ZF-5, not sure I would want to be trying to fill it on the trail.
Digger wrote:I vote fix the seal.
Not sure about your exact setup, but I can pull the Atlas and ZF-5 in around an hour if I lay the tools out beforehand and work fast.
From there, you just tip the trans on its tail and separate the case to get out the front seal. The case comes apart real easy.
Digger wrote:I'll need to check my photos when I get home. I dont remember for sure, but I dont recall it taking long to disassemble. I remember thinking it was the easiest trans disassembly I've done.
The big ? in my mind was whether you need to replace expendable parts like the freeze plugs.
Digger wrote:Yikes on that input shaft! Glad you can repair it.
Did you need to remove the freeze plugs? I couldnt fin any photos where I did that, but I remembered them.
ThanksEck wrote:I would try to follow these instructions: I had about every issue known to man trying to bleed my system and could not get it to bleed until I finally decided to put a different slave cylinder on mine. Basically had a faulty/leaking slave right out of the box. When I put a different one on, it took about 10 minutes to bleed.
First things first, because it took me a while and lots of frustration to figure this out, REMOVE the rubber diaphragm in the MC (under the cap). Your master cylinder should come with a short bleeder hose that you insert into the MC where the hydraulic hose goes and loop the other end back into the reservoir. Fill the MC with fluid and have a helper pump the clutch pedal. Fluid (and a bunch of bubbles) will cycle through the hose, back into the reservoir. After several pumps, quickly remove the bleeder hose and stab in the hose going to the slave cylinder.
You’re half way there. Now you need to bleed the slave cylinder, find a wrench the fits the bleeder valve. The ford manual had the best instructions I found and they go something like this. With the bleeder CLOSED pump the pedal 10 times pausing for 1-2 seconds at the top and bottom. On the 10th pump, hold the pedal to the floor. Crack open the bleeder for a few seconds, some combination of air/bubbles/fluid willout, close the bleeder, then release the pedal. Repeat. It probably took me about 12-15 times to get a good pedal feel. Don’t forget to check the fluid level as you go, it’s a small reservoir! When done put the rubber diaphragm back in and cap it off.
If you follow these exact instructions it should only take about 20-30 minutes and minimal frustration. As a side note you can do this alone.
Jesus_man wrote:I seem to remember having to use a pry-bar on the slave to get mine to bleed enough.
Gunnibronco wrote:I have about 500 miles on things, mostly off road and it's doing well. If I shift too fast, especially with lower t-case gears engaged I'll get a buzz moving into the next gear.
