Best Power Steering Conversion Kit
Postby BSpick » Fri Sep 03, 2021 7:22 pm
I think I'm finally done dealing with the old manual steering and want to upgrade to power. Any suggestions on what and who has the best kit? I already have the dual pulleys... They all look pretty similar to me, so does it come down to price and shipping? Thanks for any suggestions!
https://www.cjponyparts.com/borgeson-po ... 7/p/PSK25/
https://www.wildhorses4x4.com/product/4 ... ering_Kits
https://tomsoffroad.com/parts/66-77-for ... ower-shaft
https://shop.broncograveyard.com/1966-1 ... nfo/12893/
BSpick
Re: Best Power Steering Conversion Kit
Postby Justin » Sat Sep 04, 2021 4:17 am
How set are you on a kit? I suspect you could find the components and save a few bucks if you're OK with used. Otherwise, I've tended to prefer Wild Horses as a vendor.
Postby BOBS 2 68S » Sat Sep 04, 2021 4:27 am
X2 on Wild Horses.
BOBS 2 68S
Postby Digger » Sun Sep 05, 2021 2:03 pm
Wildhorse and BroncoGraveyard look like they are using the Delphi 600 box off of a Xterra with a swapped sector shaft. Mostly likely a Borgenson kit like what came with my truck. You're GTG with either option.
Postby dbasile » Wed Sep 15, 2021 9:06 am
I have a full power steering set up I will sell you. Worked perfect. I pulled it only due to going to a hydroboost set up then I changed my set up stretching the wheel base and used a 79 box.
I have the original canned ham style box and a saginaw with duel returns.
dbasile
Postby BSpick » Fri Oct 08, 2021 5:48 pm
Definitely interested in your set-up. I sent you a PM.
BSpick
