Updated: Timing cover leak
Postby Gregg » Sun Nov 21, 2021 2:28 pm
I've been having a slow coolant leak for a couple months and I can't see to find it. It's been pooling to the right and left of the water pump on the block (just below the heads which is why I think I had smoke in the engine bay coming back from Platte River Grill) ). It's also been running down along the oil pan on both sides. It seems to leak until the radiator is 2/3 full and then it stops leaking. I've checked hoses and none of them seem to have any coolant dripping from them. Any suggestions or tests to narrow this down would be great. Thanks!
Gregg
Re: Trying to find where coolant is leaking
Postby Eck » Sun Nov 21, 2021 2:48 pm
Gregg wrote:I've been having a slow coolant leak for a couple months and I can't see to find it. It's been pooling to the right and left of the water pump on the block (just below the heads which is why I think I had smoke in the engine bay coming back from Platte River Grill) ). It's also been running down along the oil pan on both sides. It seems to leak until the radiator is 2/3 full and then it stops leaking. I've checked hoses and none of them seem to have any coolant dripping from them. Any suggestions or tests to narrow this down would be great. Thanks!
You can get a loaner vacuum coolant leak testing kit at most auto parts stores. You can pressurize the system and then try to see if you can find where it’s leaking from.
Postby Viperwolf1 » Sun Nov 21, 2021 5:25 pm
Thermostat gasket or hoses. Can be head gaskets too.
Sent from my SM-G781U1 using Tapatalk
Postby Jesus_man » Mon Nov 22, 2021 8:49 am
I had a pesky leak on my TDI I couldn't track down. Borrowed a pressure test kit and bore scope from Autozone to find them. Would recommend that as well, just not sure what connections you have available to add pressure. To test the system post repair, I actually hooked my bike pump to a small overflow connection on the radiator and plugged the hose that came from there. That worked great, but I don't know if you have a similar connection. About 15psi is all you need.
Postby Gregg » Mon Nov 22, 2021 11:15 am
Thanks guys. I’ll post up after I pressure test.
Gregg
Postby Kinder » Mon Nov 22, 2021 4:48 pm
Pressure test will help find it. It can be a bit tricky if it is only leaking when the truck is running or the system is hot. We just replaced the water pump on TFB, it didn’t show up on a pressure test, but when I pulled the belt the shaft had lateral play and the weep hole was showing signs of the leak.
Postby Gregg » Wed Nov 24, 2021 8:58 am
I rented the kit today. I haven’t looked at any videos yet but I’ve got 3 basic questions before I run the test:
1. Should I top off the radiator?
2. Should I run the engine to circulate / warm the coolant
3. Any other advice
Gregg
Postby phyler » Wed Nov 24, 2021 9:03 am
Gregg wrote:I rented the kit today. I haven’t looked at any videos yet but I’ve got 3 basic questions before I run the test:
3. Any other advice
I haven't done this to the Bronco, but have had to do it on other vehicles. No need to warm up the engine. The only thing you would do that for is if you need the t-stat open. I would top off the radiator just as good practice.
Otherwise, it's straight forward of just adding air.
I would comment, look at the t-stat housing. I had a crack in mine that I missed and it caused me all sorts of grief until I finally saw it. I think I went through like 3 or 4 gaskets. Oh, and Napa has a really nice gasket that has some adhesive so it would stay in place.
CCB Admin
Postby Jesus_man » Wed Nov 24, 2021 9:49 am
Yeah, top off the rad because you say it seems to stop leaking at a certain point. You could just add distilled water in for now instead of potentially wasting coolant??
The thermostat will have enough bypass to allow the whole system to pressure while cold.
15+/- psi is enough. Shouldn't need to go higher. If you can't readily find the leak, leave it pressurized for a while until perhaps it will start puddling.
If still no leaks, check the oil. Hope it's not milky!
Postby Gregg » Wed Nov 24, 2021 2:43 pm
Thanks. I rented the tool and it worked okay (the gauge didn't work). But I got enough pressure in to start the leaks. It looked like it was coming form the sides of the water pump gasket on both driver and passenger side. There might be a little coming from the thermostat gasket.
Plan of action ideas:
1. Replace WP gasket and Thermo gasket
2.) Replace WP , WP gasket and Thermo gasket. How can you tell if a water pump needs replacing?
3.) Something else to try that would be easy....
I wonder if the new radiator had anything to do with it...
Gregg
Postby Eck » Wed Nov 24, 2021 2:46 pm
How old is the WP? They’re relatively inexpensive and I’d be inclined to just replace it while you’re doing the gaskets since it’s a pain in the ass to change.
Postby phyler » Wed Nov 24, 2021 6:32 pm
Eck wrote:How old is the WP? They’re relatively inexpensive and I’d be inclined to just replace it while you’re doing the gaskets since it’s a pain in the ass to change.
+2. If you're going to trouble of pulling the WP to replace the gasket, just do the pump.
CCB Admin
Postby Kinder » Thu Nov 25, 2021 8:28 am
Gregg wrote: How can you tell if a water pump needs replacing?
Any bearing play or shaft looseness on the pulley flange and the pump should be replaced, only a matter of time before the seal follows. If your old rad was leaking then you just found the next weak point, so yeah it may have had a lot to do with it.
Postby Gregg » Sun Dec 05, 2021 8:52 am
I kept all the hoses connected and removed the front dresses so I could see where the leak was coming from. It appeared that the leak was not coming from the water pump gasket but between the timing cover and the block. I’m assuming I will have to pull the harmonic balancer, drop the pan and get a gasket and seal kit for the timing cover. I did check the oil a little bit ago and it didn’t seem to have coolant in it but I’ll check again today. Any advice before I get started?
Gregg
Re: Updated: Timing cover leak
Postby Gregg » Sun Dec 05, 2021 6:36 pm
I got the harmonic balancer off , timing cover off and oil pan off. All the bolts came out easy (some too easy). No coolant in the oil pan. It was pretty clear that the coolant was leaking right by the passages. I ordered a new gasket kit ( with seal). I’ll grab some new bolts at Ace and start reassembly. When get the gaskets I’ll post up some rtv questions.
Gregg
Postby Rox Crusher » Wed Dec 08, 2021 2:53 am
Were the bolt threads worn or were they loose because the threads in the holes are worn?
Postby Gregg » Wed Dec 08, 2021 8:39 am
When we rebuilt the block I was able to clean and reuse the bolts. They were already a little worn so this time I'll put new ones in.
Gregg
Postby D&D72 » Thu Dec 09, 2021 9:26 pm
Are ya done yet?
D&D72
Postby Gregg » Mon Dec 13, 2021 9:20 am
yeah yeah yeah Johnny....
I got all the gaskets and seals. I'm finishing up cleaning all the parts before install.
1. I noticed I might be missing a sleeve on the timing belt cover. You can see in the pic that there is one on the passenger side but not the driver side. I wonder if that is a big deal? If so, where in the hell do you get one of those....
2. The water pump (less than 30K miles) didn't seam to be leaking and the seal to the cover seems solid. Also the pump spins smoothly without any play. Should I break the seal and replace the pump (I ordered one when I thought it was the pump leaking)
3. Here is my proposed install process
a. thin layer of RTV (what style/brand ?) on block and cover, gasket on cover, install cover on block, make sure cover bottom is flush with bottom of block (for oil pan)
b. cover bolts - anti-seize or sealant (what brand / type?), torque bolts to specs
c. NO RTV on pan gasket because the pan gasket is all one piece (see pic).
d. Install pan to torque specs
c. hook everything back up
4. Give it a day and fire it up.
5. Take it all back apart because I forgot something
Gregg
Postby Jesus_man » Mon Dec 13, 2021 9:44 am
My comment is in regards to 3C and 4. I have had far better success with RTV sealing properly when left to dry for a day before exposing it to fluids. So perhaps give it 24hrs before you add your fluids back in.
As to which RTV - when you got the store you will see a selection of Permatex sealants. You might need a different tube for the water side vs the oil side. They also make anti-seize.
Postby Eck » Mon Dec 13, 2021 9:59 am
Permatex The Right Stuff black gasket maker is pretty much all I use at this point. It sets pretty quickly and is pretty easy to lay down.
Postby Kinder » Wed Dec 15, 2021 11:26 am
Regarding item 1 above. I think it’s an alignment dowel used in the factory for assembly. Likely not critical, they are also found in between the block and cylinder heads, and the block and bell housing. The only set that I consider needed is the set in the heads, unless you are using studs for installation.
Postby Gregg » Thu Dec 16, 2021 8:05 am
Thanks for the replies guys. Any thoughts on the breaking the seal on the old WP for a new one (#2)?
Also, I imaging I won't use the bottom corners or curved piece in this Timing cover gasket kit?
Gregg
Postby Kinder » Thu Dec 16, 2021 10:10 am
Gregg wrote:Thanks for the replies guys. Any thoughts on the breaking the seal on the old WP for a new one (#2)?
#2, it’s a judgement call, if it seems good it likely is. You are running an explorer front dress right? If yes, then swapping out the WP isn’t that painful as nothing else is in the way for R&R.
Correct on the gasket kit, you’re using the one piece so the bits in the kit aren’t needed.
Postby Gregg » Tue Dec 21, 2021 9:00 pm
Finally finished getting old gaskets and gunk off. I ended up replacing water pump and assembled back to the timing cover and block. I used a thin layer of rtv on the gaskets. I replaced bolts with grade 8s and torqued them to specs with anti-seize. Next I put the oil pan on and torqued that with a little rtv in the corners. Tomorrow I’ll connect the hoses and front dress and get ready to fill up with fluids.
Couldn't find the torque specs for the alt and ps brackets. I just gave them a good old fashioned tightening.
After reconnecting the alternator I posted up a question about grounding the battery.
Thanks. I'll post up after I fire it up.
Gregg
Postby Gregg » Sat Jan 29, 2022 11:42 am
I've fired it up a few times and the test runs went great. No leaks as of yet and its back too being my daily driver (minus icy or mag chloride days)
Thanks for the guidance.
Gregg
